0 Members and 150 Guests are viewing this topic.
Void
Hey guys. Can anyone direct me to a schematic for a circuit that has been tried and tested which
will trigger off a pulse waveform, such as an output from the TL494, and which will create another pulse train
of the same frequency with a continuously adjustable phase delay, allowing setting the phase delay
angle from 0 to 90 degrees?
Jeg
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg465146/#msg465146
Hi Void, just an idea for triggering you.
Take a look at what i had used in the past for an experiment of mine. The one turn takes the trigger signal from yoke, tl072 shifts the phase, and the pulse train is produced at 4066. When 4066 takes the triggering pulse, opens the door and HF pulses are passing from my fg to the mosfet driver. Hope it will give you an idea
Void
Quote from: Jeg on February 15, 2016, 02:04:54 AM
Hi Jeg. Thanks, I will take a look. It sounds like you didn't have full phase shift from 0 to 90 degrees with this circuit?
Maybe someone else can point to another circuit that is tested that will trigger off the output of the TL494 or similar,
and which gives a full 0 to 90 degrees phase delay adjustment at the same frequency. I think this little bit of circuitry is
probably an essential component to have working well.
Jeg, what is this 'blue box' circuit you are testing?
Jeg
If you see at Allega's circuit for Ruslan replication, the blue box incorporates a way of synchronizing the peak of current inside the inductor loop with a high frequency component. It takes a pulse out of the tl494, and makes a trigger pulse adjustable per phase and width, to activate a mosfet with a tesla coil secondary.
Void
Quote from: Jeg on February 15, 2016, 02:49:14 AM
Hi Jeg. Thanks! It sounds like this is the type of circuit I am looking for.
Have you tested this circuit yet? Does it give you a full 0 to 90 degrees phase shift?
If so, I will go ahead and order the parts... :)
