0 Members and 112 Guests are viewing this topic.
Tomtech29
"Void"
better that I did not specify .
-Power consumption of kacher: 24 V  1.8-2 A
-Totaly 260w and When kacher run Power consumption totally 9-10A(24V) is to strengthen the long way:D
question to:"Verpies"
...of the Tl494 I mean some unusual combinations or something that kind of shift in phase how you want it done?
-or Itsu already has a finished project with a double primary winding yoke?
Void
Quote from: Tomtech29 on February 15, 2016, 04:01:50 PM
"Void"
Plugging the light bulbs directly into a mains socket is just as effective, but much simpler. :)
URFA
Hi Geo and all.
First of all I want to say, I have not had time to develop my setup.Sadly, I would say that my setup did not OU %100. But my setup had the a chance. I haven't a osciloscope. You can not succeed this system without oscilloscope. "URFA also mentioned that he saw no effect from connecting earth ground when he was running from batteries" My setup can run hot end of the grenade and only ground.(when running from bateries) And when kacher run, the effect is do  %100.
1 year ago I run 420w brightness of bulbs %100 full and with 24V 11A(With kacher). And I measure output voltage 190V 2.2A.I could not record a video. I want to say something friendly.I ruin the my setup, while trying to improve. I changed secondary of the kacher and inductor coil then I could not get strong effect. After I did a lot of experimenting.But I did not get strong effect like my first setup.Frequency of the Kacher is very important.I was not working on this system for a long time.My advice to you,if you have not the an oscilloscope,do not waste your time with my setup. I found random frequency harmony and after I lost effect when I editing my setup. Now I ordered some electronic materials and I will work on other system again.
Geo: I used Akula Pushpull Circuit from his first device in my setup. The scheme below. My Friend I advise you work on the system of the Alexee Sergey.I believe that his system will work.And it's easy and understandable explanation.
Good luck everyone
Ibrahim.
itsu
"Void"
TT, yes,  see this post for a screenshot:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg460729/#msg460729
Follow the 2th link there to way back to see more about this.
Itsu
Void
Quote from: URFA on February 15, 2016, 04:35:51 PM
Hi URFA. What I was referring to was based on what you stated here previously in regards to
earth ground not improving the performance of your setup in any significant way:
"I think it is not necessary connected to earth (To my way of thinking ) I don't any different effect when I connect it to ground."
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg423137/#msg423137
"I have effect of the ground now in my experiments.  But when my power supply connected to the network effect is bigger. And when I use battery,the effect of the ground verry little."
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg422658/#msg422658
1 year ago I run 420w brightness of bulbs %100 full and with 24V 11A (With kacher). And I measure output voltage 190V 2.2A
Previously you stated:
"In my setup.
Power consumption of push pull driver circuits: Without kacher 24V 2A but I measured when kacher runing Its power consumption is growing about 24V 7-8 A.
Power consumption of kacher and push pull driver totally 9-10A(24V)
I have 4x40w and 1x100w  220v light bulbs. Totaly 260w and When kacher run they are fully brightness.
My setup not OU.I only share this video with you to show the effect of Kacher. I'm still working on this system like you."
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg421773/#msg421773
I guess you are you talking about a different test later where you powered 420W of light bulbs?
If you really measured 190V at 2.2A (potentially around 418W, i.e.  if no phase angle) to the light bulbs, with 264W input power consumption, then yes,
that would an interesting result. Were they all filament type light bulbs, or were some of the lights other types?
Were you powering from a battery or mains connected power supply?
Where can info be found on Alexee Sergey? His name sounds familiar...
All the best...
