0 Members and 121 Guests are viewing this topic.
GeoFusion
Hi Guyz :)
  Ibrahim,
Yes I see we are on the same page friend :), that is the Push pull circuit I also use and replicated and using for the Device :),
the circuit is also designed on pc to make it more readable
I attached the schema below, same same Akula Circuit. But I need to be carfull next time not to remove ground ,
That Is what happened and destroyed my push pull. Kacher is ok and PSU 24V.
Nice man You did witness amplification, form 24V 11A with kacher, and putting out 420W out :)!
Yess!!  Alexee Sergey :)! that system will definitely work and looks simple but will need good oscilloscope to do this, I got one from a friend but
I am using it to see the freq. but will need a better one.  This setup is So close to
I have  all File of Pictures  completely and Schema's of Sergey ,it is 1.75GB file with everything and videos and close up videos :).
collected few more onRealstrannik russian forum.
Will take time to replicate this one when I do.  it's easy and understandable explanation on schemas.
The Effect is something beautiful when it's doing it's work :).
Thank you.
All,
Below I have posted my circuit I used , the same Ibrahim used too.
Akula circuit.
Everyone Success and Colaborate on the topic. With more minds it will succeed.
Cheerz~
8)
itsu
Quote from: skywalker66 on February 14, 2016, 06:03:36 PM
Itsu,
if you disconnect snubbers or/and the 2 tvs (D7, D8) the lag between gate and drain keep the same ?
Usually snubbers are placed across coils and much less sourse-drain of mosfets.
Try at first disconnecting the 2 tvs and note the difference, and then snubbers.
Drain / source diodes removed, TVS's removed and finally the RC snubber removed.
This brings back the ringing on shutdown, but still the drains seems independent from their gates, so something else in my setup is wrong.
I blew up one MOSFET driver in the process, so need to replace some parts again, then will try with a resistive load first like suggested by T-1000.
Itsu
verpies
Quote from: itsu on February 16, 2016, 04:23:20 PM
Does a purely resistive load connected to the secondary winding have a symmetrical bipolar AC induced across it ...or unipolar pulses?
You can make this test with decreased drain voltage to protect your components from damage.
NickZ
    Geo:
    Wasn't that hand drawn diagram the one that Akula mentioned was NOT made by him, and that it's NOT correct?
However, that yoke driver circuit may be good.
    That design does seam fairly simple to build, but is that any better that using the commercial TL 494 board and fet drivers?
    Sergey's circuits look more complicated.  And we still don't know if they will allow for a self runner.
    As it seams that URFA has given up on the project, and there's no news or confirmation of a self runner from Sergey, it may be up to you to continue on with all this. More than one of us would jump in, even Hoppy, should you show something interesting.
magpwr
hi everyone,
There is also newer version of Sergey circuit with built in nanosecond/interrupter selectable via jumper,PWM, generator along with a one of a kind 1 button toggle power on/off switch circuit.
It nearly contain everything in one PCB board with the exception of the  mosfet or igbt for the toroid and kacher.
I just took a look at the image last night believed to be from 1GB + torrent file.I can't believe i accidentally overlook this image previously.
I have attached a resized version.Please dig for it if you want the original image.
If you want it built it yourself.Good Luck.
Unfortunately a scope is a important requirement.
If you don't believe in something.How can you even start or continue bother talking about it. :D
Back to old history Ruslan did not reveal any circuits it was Oleg or someone else whom reveal the circuit of Ruslan.
There is nothing else to talk about Tariel Kapanadze device except that it works and the frequency of spark originated from spark plug(As heard in old video) is very low like somewhere around 2 to 10 times a seconds.
Latest update-
I have attached a crude working circuit diagram(in use) of Oleg and Sergey interrupter working together using 2x 74HC132.This version less confusing than the Sergey circuit.
I am using IXDI614 (inverted) mosfet driver which can handle up to around 2Mhz.The individual pulse width around 80 nanosecond is taken across my 1.2kv SIC mosfet source-gate.
