0 Members and 73 Guests are viewing this topic.
itsu
Quote from: Hoppy on February 18, 2016, 06:27:07 AM
Itsu,
Is your 15V regulator getting very warm in comparison to when you are running just on resistive loads without the primary windings connected?
Hoppy,  no, no diffference noticed.
Itsu
Hoppy
Quote from: itsu on February 18, 2016, 07:00:46 AM
Itsu
Hmm, I think we need Verpies on the case!
Dog-One
Quote from: itsu on February 18, 2016, 06:59:48 AM
yes that is what it looks like, but as i tried the Oleg green box snubber setup (similar as yours), it did not change that problem.
Yes, that's why I mentioned the core and the number of turns on the primary.  I have a hunch you are pushing the core just into saturation and it's kicking back overly hard.  I ran into a similar problem when using too few primary turns on a less than optimal core.
The setup I have now will run unloaded on the secondary consuming only about 50mA.  When loaded it drives to about 5 amps by adjusting voltage.  So it has a nice working range and is predictable.  I do have the snubbers which protect the MOSFETs and there is a little bit of ringing with certain loads.  I went through a dozen or so cores and many different winding configurations to finally get it where it is now.  The Sendust cores I started with worked okay for resistive loads on the secondary, but failed miserably with inductive loads.  Using 14.5 turns on each primary with this nanocrystaline core is the most optimal I have found so far.  Still using the same IFRB3077 power MOSFETs.  I also have a 1000uF 50 volt electrolytic capacitor very near each MOSFET acting as a current dump when the MOSFET turns on.  I'm also using very large traces on the PCB with a grounded backplane (bottom foil).
Hoppy
Quote from: Dog-One on February 18, 2016, 07:32:50 AM
Would it help to choke the mosfet supply line current?
Dog-One
Itsu,
I just thought of something for you to try...
Add a fairly large inductance, current handling capable choke between the center tap and your positive rail and let us know what that does/changes.  This is what I did to finally figure out my core wasn't optimal.
