0 Members and 536 Guests are viewing this topic.
itsu
OK,  back to the basics, coils removed and 2x 100 Ohm resistors installed instead, RC snubbers on drain/source still in place (no diodes)
1.8 Ohm gate resistors measured ok, the bat 42 diode across it won't measure properly in this situation.
Pin 3 (enable) on the drivers still floating.
24V supply voltage shows stable (purple)
screenshot shows:
yellow 1 MOSFET drain
blue same MOSFET gate
purple 24V supply voltage (middle tap)
All referenced to ground.
Itsu
Hoppy
Quote from: itsu on February 19, 2016, 09:43:24 AM
Hoppy,  verpies,
the 54V TVS specs were posted here:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg474113/#msg474113
I notice that they worked fine when directly across the drain / source of each MOSFET, but yesterday i had moved them directly across the primary coils,
but then the setup started to oscillate when more then 8V on the drains, so i have removed them now.
Itsu
Looking at the spec sheet, I can see that the max operating voltage is 54V, so I can understand why you had a problem with the diodes directly across the primary coils. To be safe, I would uprate the voltage a little if you put them back across your mosfets.
magpwr
Quote from: itsu on February 19, 2016, 10:01:45 AM
screenshot shows:
Itsu
hi itsu,
Can you try force enable mosfet driverwith a ~1k resistor rather than leaving it floating.
Any floating pin including trim pot can easily pick up noise from external.
I can't tell is it your scope or the noise that is producing such a thick lines for the waveform
itsu
Thanks Hoppy,    so something like 60V should do.
OK,  RC snubbers removed, for the rest same situation as above.
Yes Magpwr, thats my scope,  now set to averaging 4x
Itsu
verpies
Can your scope have just the CH3 (purple) in the AC coupling mode to better visualize any supply voltage ripples?
