0 Members and 85 Guests are viewing this topic.
Hoppy
Yes, an excellent ride. Thanks to all who contributed.
T-1000
Quote from: magpwr on February 20, 2016, 10:55:38 PM
Tariel is indeed different from Tesla because Tariel focus was on current movement to Earth and Tesla did ever light a bulb few feet/meter from tesla coil.
In Tariels case and Ruslan case, there was quite interesting tesmpeak conference on last Friday:
https://yadi.sk/d/f0qWJuBepCaqQ - Ruslan's new tuning approach
Ruslan generally told he is looking for natural resonance with maximum current sudden rise in grenade coil first with small resistance attached on low frequency range then builds push-pull for that frequency. Only then he adjusts Tesla coil frequency to be multiplier of close harmonics to the natural resonant frequency of grenade coil. Not way around, all what Tesla coil is needed for - just spikes, so no katchers.
In the end of conference he mentioned about overcomplicated setup of akula with 2 PLLs and how much trouble that was. So i came up with idea:
For example, the PLL on grenade locks on 15kHz, so the Tesla coil driver will need to be adjusted: 600kHz or 1,5MHz, or 3MHz but also there will be resonant harmonics between to choose for fine tuning which is close to natural frequenc of grenade coil. To do that we multiply frequency of PLL frequency  by 10 from 10 to 100 for crude adjustment then multiply by 1 from 1 to 10 for fine adjustment. The resonant harmonics never go out of division and multiplication ranges so we can use this in our advantage. Also the TT is not ment to be like katcher. We do not need much of self-resonance in TT (voltage). But we need self-resonance in grenade coil which will have maximum current and phase + frequency locks. So when 2 signals mix they add to each other. For multiplying it is like variable frequency but always on locked resonant harmonics so you pick up next harmonic instead of frequency not in harmonics. It is like tuning of piano octaves :) The wrong set of 2 frequencies cause bad sound there when playing music. There you have octaves for crude frequency shift and notes in each octave for fine frequency shift. It is same with resonant harmonics which we need here. Which means in Tesla driver we need frequency synthetizer for multipling PLL frequency -  http://m.teachastronomy.com/astropedia/article/Resonance-and-Harmonics
So lets say, our octave contains 10 notes: f,2f,3f,4f,5f,6f,7f,8f,9f,10f. We need 10 octaves. So the crude shift - 10f,20f,30f,40f,50f,60f,70f,80f,90f,100f. Then fine shift in each for selecting note. As that is in nature, it should work also in what we are trying to tune :) As an  example, 64f from 15kHz = 960kHz.
NickZ
  T1000:
  That all sounds very complicated.  Didn't Ruslan just turn some trim pots to adjust the frequency of the three turns coil to best match the 168t coil,  thus providing it's best output?
   How does he find what is the best (natural?) running frequency for the grenade? Or is it just whatever that output coil, 37.5 - 40 meters long, is running at, without any adjustments there. Then the 3 turns coil is matched to that 168t coil frequency, by turning the pots.  Then after that the Kacher is matched to provide the most gain to the induction circuit's output?  Or not?
   Itsu: You mentioned:
   "So knowing this all, we can say that this push-pull circuit is doing what it suppose to do."
        end quote.
   So, can you tell us what you're getting at the bulbs?  How many 100w bulbs can it light, how bright are they, etz... with and without the HV interaction.  Can you observe any gain from the HV onto the induction circuits, yet?
T-1000
Nick,
There are always several approaches for it but the some things remain constant. The max current in grenade coil, the standing waves as well and the current pumping effect over ground wire. Also the high voltage spike from Tesla coil/nanosecond pulse generator which match resonance is there too. And that is locked on relationships of resonant harmonies.
I also got involved in replication of device in UK so will keep you posted if will manage to find simple way for getting at least unity.
Cheers!
GeoFusion
Hi  guyz :)
Nickz,
Yes, for what you just said  about adjusting the freq using the pot and to yoke with the 3 turn coil + cap series on grenade,
Here is one of my recordings doing the reading and figuring it all out.
https://www.youtube.com/watch?v=SdYGq_jhmeg
This what needs to be done in the 1st place for what I have learned up till now :) with push pul, When done with that, only then Applying Tesla coil/Kacher
to the system for amplification and effect.
3turn coil and cap has to resonate and will see good output on grenade. the right freq needs to be found.
Easy way out it connecting a 7W bulb as indicator to grenade and the keep tuning the pot till you see the 7W light to a certain degree.
Then you know you reached resonance, this is without  scope. :) every capacitor you place will have a different
resonant point.
T-1000,
I was recently on RealStrannik forum and wanted to ask you something they are talking about and heard Ruslan talking about it too.
What are OEDs??? EODs emissions.
I do know what EDS are   ....  EDS - transverse waves (when an alternating current and the alternating magnetic field
- is excited in the secondary housing proprtsionalny current)
EODs, to me they are talking about the system reaching or having Longitudinal waves and spin wave just like out solar
system does. Ions- Radiant energy is surely involved in this.
btw check PM inbox ;).
   Itsu,
Glad to see your on your bench back :),
give my setup a try and try to do readings, I still did not get my parts to continue the work.
But keep it up man, and the rest!
         Cheerz~
