0 Members and 41 Guests are viewing this topic.
NickZ
  You don't give up, do you???
  Ask ION, he'll tell you...
ramset
Nick Z
When Making your point ,please don't involve others with out their Consent nor infer any position whatsoever on their behalf.
Not a good Practice.............
thx
Chet
Thanks Grandma
Void
Quote from: Hoppy on May 07, 2013, 02:47:38 AM
What about the suspicious looking white wire seen briefly laying on the earth just off the edge of the concrete slab behind the demo table. Also, did you notice that when he lifts the demo board to reveal the top of the table, the right hand side corner never leaves the top of the table.
Hoppy: At what time stamp in the video do you see what you think looks like a white wire laying on the ground? I don't see it. Also, I think if you review the new video again you will see that he does lift all four corners of the demo board off the table. First he lifts clear the two corners on the right hand side, and then he goes around and lifts both of the corners on the left hand side. By the way, that white ground wire that goes from the well to the house in this video can also be clearly seen laying on the concrete several feet away from the chair in the previous Akula video as well, but it seems to come no closer to the chair in the previous video than several feet away. It doesn't look like it has any other wires coming off it.
Void
Quote from: NickZ on May 07, 2013, 12:03:08 AM
  I need some caps, the ones I have don't work, as they are start caps, and I need some run caps instead. So, it won't work like it should without them, that is my main hangup now. And they aren't that cheap to buy, or close by, for me to go get them, either.
  The cap that is in series with the yoke is what is taking the place of the spark gap, yes it's true. I may just have to make one just to prove the point. But, it has already been proven.  I'm also still working on how the choke works, and what cap to use on it, to get it to resonate with the magnetic resonant frequency. The caps are very important in this device. Notice how on the SR 193 video, the kid is touching the ground wire, shorting the start cap with his bare hand, and stating that the spark gap doesn't have to be very strong, and noisy. His make no noise.
  Anyway, I do have mine working on a low output levels and lighting incandescent bulbs, already, using low voltage and low current only, that won't kill me. Until I learn the stroke.
  More to come... I'm not giving up on this... I just have to take it slow and easy, as it's a no budget thing.
I am with you that the Kapanadze and Akula and even the SR193 videos all do seem fairly sincere, but the possibility still exists that any or all of these demos could be fakes. I can't blame anyone for being skeptical as there is good reason to be skeptical about any free energy videos as such videos are not so hard to fake if a person wanted to.
In a prior video akula mentioned setting the primary coil driver circuit for series resonance to generate a high current in the primary windings. If he is using a large value cap to do that as he seems to be doing, then he must be setting the primary circuit series resonant frequency to a fairly low frequency. If we estimate the combined series inductance of the yoke three turn output winding and the ten turn main coil primary winding (those are the turn counts listed on the hand drawn schematic anyway) at about roughly 25uH, and if the series capacitor is 5uF (not sure what he actually used), then the approximate primary series resonant frequency whould be somewhere in the vicinity of 14kHz. So, he would also have to set his transistor driver circuit to that same frequency to drive the primary series circuit at its resonant frequency. If the so called choke coil is connected in parallel to a capacitor and nothing else, then I would guess that the resonant frequency of the parallel combination of the choke and a capacitor should also resonate at the exact same frequency that the primary series resonant circuit is resonating at (14kHz or whatever the exact resonant frequency of the primary series circuit actually is).
I have tested the series resonant configuration to drive a primary and it can drive the primary with a high current (you need to use a step down transformer from your driving circuit), but it will not be a very high voltage across the primary, and it will be a sinewave driving the primary rather than pulses that a spark gap would generate. At least you do get the high current drive to the primary that is somewhat comparable to the current that a spark gap driver circuit can deliver, although not delivered in pulses like a spark gap generates.
Hoppy
Quote from: Void on May 07, 2013, 11:53:47 AM
Hoppy: At what time stamp in the video do you see what you think looks like a white wire laying on the ground? I don't see it. Also, I think if you review the new video again you will see that he does lift all four corners of the demo board off the table. First he lifts clear the two corners on the right hand side, and then he goes around and lifts both of the corners on the left hand side. By the way, that white ground wire that goes from the well to the house in this video, can also be clearly seen laying on the concrete several feet away from the chair in the previous Akula video as well, but it seems to come no closer to the chair in the previous video than several feet away. It doesn't look like it has any other wires coming off it.
Look at 0:46 on: http://www.youtube.com/watch?v=v_2rinvpvrM
The wire / cable is laying under some vegetation on the garden, not on the concrete slab. The camera shot is very brief.
