0 Members and 151 Guests are viewing this topic.
Jeg
Thanks guys
I use an IR2110 driver so I'll borrow only the output part of the lossless clamp circuit. Two schottky, two caps, four primaries. TL494 has minimum fixed dead time 4% so it is protected. Even I have enclosed my push pull board, there is some space for 4 components more.
Void
Quote from: John.K1 on February 27, 2016, 04:35:27 PM
BTW I did the test of  two small Tesla coils right next to each other and having feeling .........not yet. I have to inspect it again tomorrow- but in any case -it looks very interesting. Possibly exactly as Romanov said and showed. Coincidentally I read two documents supporting this theory too. Need to sleep on it now ;)
Hi John.k1. Sounds interesting. Let us know how your tests go... :)
John.K1
Quote from: Void on February 28, 2016, 03:42:26 PM
Hi Void- what the coincidence :)  just made a picture for you ;) Please tell me where is the mistake in my setup.
Void
Quote from: John.K1 on February 28, 2016, 04:35:46 PM
Hi John. Is your goal to compare output power to input power?
If you want to get an idea of the output power, try this:
If you have a non-inductive type resistor, such as a carbon film resistor, you can just connect a resistor
across the output of the second tesla coil and measure the voltage waveform across the resistor on your scope, to get an
idea of the output power. For a clean sinewave, Vrms ^2 / R = the average output power. This should give you a half decent
estimation value of the output power. You can try different non-inductive resistor values
from about 10 ohms to 10K ohms to see which gives the best output power.
For a clean sinewave at the output, if you take the peak voltage of the sinewave measured on your scope
across a load resistor and multiply the peak voltage by 0.7071, then that gives you the RMS voltage.
Dog-One
Those current sense transducers only go to about 200kHz.   ;)
