0 Members and 75 Guests are viewing this topic.
GeoFusion
Hi Nickz :)
This Chaotic mode is different for sure Nick, it is not the same as how a yoke does on a mazilli circuit.
It's when you reach the right tuning or lets say getting close to a good Synchronization.
Imagine heaving speakers creating queels and distortion on the device.
Mediator Toroid and yoke are making the same noises when it happens.
only happens when the Kacher / Tesla is on. if pushpul is on without kacher there is no chaotic Synch.
But remember this, This only happens in this particular setup where I have this 4inch toroid as mediator it will happen,
for what I know up till now. Ibrahim also witnessed it, we can all hear  it in the videos back on my channel.
You will need atleast a TL494/iR2110 pushpul circuit. pot for Duty Cycle and pot for Frequency.
Duty cycle at final stages of fine tuning led me to this recent effect and keeping resonance on inductor with freq pot.
Akula and Ruslan, They have it silent because somehow they know how or where to silence it,
Might be because they don't use mediator core.
Soon others will replicate the system without the use of toroid as for a madiative form,
Using circuits instead of the toroid.
as seen How Akula has done it , Ruslan and Sergey.
Cheerz~
NickZ
  Geo:  Yes, I've watched your videos, and am aware of the load hissing noise.  But, the "chaotic mode" that we have talked about previously by Itsu, was from the induction circuits and yoke/grenade, and it's ringing sound, even without the addition of the Kacher's output. And it certainly does not kill if the duty cycle is raise beyond 30%. Or, producing no light, if the Kacher circuit is not operating.  So, there is a difference from the yoke's normal ringing or chaotic mode to your hissing mode.
  Your system was resonating (and ringing) at 10khz, as I mentioned in my video of your device. That is it's normal induction running frequency. The hissing noise is something else, again, and is not something that Ruslan has had, nor Akula.  So, I'm not sure it's something to avoid, instead of pursue.  We'll see, but up to now none of the efforts anyone has come up with have produced a self runner.  And what has me worried is the lack of output at the bulbs by those running from a Tl 494 circuit, from a 24v, 15 PS, and which will not light a 100w bulb, or higher wattage bulbs.
  We'll see what happen once Itsu gets his HV circuit going.  Still holding my breath...
Jeg
Quote from: itsu on March 01, 2016, 04:25:10 PM
Jeg,
When i connect my FWBR directly to the grenade (28 turn secondary disconnected) and load the FWBR with the 40W bulb, i have 207V DC during resonance across this bulb.
Itsu
Thank you Itsu.
Did you notice your current drawing at your input while extracting this 207V dc across the 40W load?
itsu
Quote from: Dog-One on March 01, 2016, 04:51:06 PM
Exact same behavior as mine.  This cycling (as I mentioned previously) is probably due to the caps in the power supply holding voltage above some threshold until it can no longer satisfy the demand.  Once it turns off, input power catches up and the power supply restarts.
When increasing load to the power supply, just before the point when this cycling starts is unity.  Then you compare input power to the PWM against output power from the PSU; that difference tells you the minimum power gain needed to be self looping.  I would expect with your loss-less clamp circuit this difference to be somewhere between 50 and 100 watts, or 10 to 20 percent.  It could be higher if you detect any heating in the yoke or grenade/induction coils.
Tinsel has stated on numerous occasions if you can develop a device that provides 30% power gain, he guarantees he can loop it.  This is what we are shooting for.
Dog-One,
i understand what you are saying, but it don't make sense to me, the 24V from the battery is always there (untill in remove it), so there
is no need for the yoke system/resonance to collapse which it seems to do.
It looks to me more like some slow oscillation due to interference, but we are talking about DC, unless there is some kind of charge / supply
cycle going on in the battery.
I have a big diode at the PS side, perhaps i should also put one at the battery side.
Thanks,  Itsu
itsu
Quote from: Jeg on March 02, 2016, 01:35:48 AM
Thank you Itsu.
Jeg,  yes it always is around 5A when in resonance.
Itsu
