0 Members and 43 Guests are viewing this topic.
Tomtech29
Quote from: magpwr on March 03, 2016, 08:30:24 AM
hi Tomtech29,
I am not familiar with the circuit shown unless you got a schematic at the driver side.
Since i have worked with 3525 few years ago as my 1st PWM i/c .I think it's got 450mA output compared to lousy TL494 at mere 250mA.
Maybe you want to try to remove i/c and connect it to a proto board and do a test.
I have attached a hand drawn version of the 3525 done few years back. :D
Pin 14 and pin 11 is the output.
Not forgetting pin 1 and pin 9 is connected together.
Thank you for your answer
another scheme on a universal PCB board work done but do not know how to run the system.
This scheme is as if he wanted to plug in
what was I missing?
kolbacict
itsu.  where did you get the Russian capacitors?
may be МБГО,МБГЧ?
Void
Quote from: Jeg on March 03, 2016, 02:21:28 AM
Hi Void, thanks for sharing your experience. :)
Smaller hissing but exists, happens to me even with no active HV. When also HV comes into play, things get worst. I remember, in some cases with my previous setup, things got better when i was connecting earth ground to my metal pots together with the (-) of the battery.
Hi Jeg. Yes, the HV makes everything a little more challenging. I tried using grounding at different
points, including grounding the metal pot bodies. In some cases earth grounding the pot bodies
acted the same as me touching the pot with my finger. It caused the bulb to get brighter at certain
frequencies, but the PWM would draw more current. I have been doing a lot of different tests in the
last several weeks with the goal of looking for what might possibly cause an OU effect. I have a few
ideas on this, and I haven't ruled out something like NMR or spin waves either. The particular testing I described
in my previous comment was deliberately done at low power level to see if I could notice anything out
of the ordinary with the spark gap and driving with PWM pulses at low power levels. Nothing unusual was noticed.
I have various other tests planned as well, including driving the coils at a much higher current level as was done in Akula's setup.
I am taking it step by step. I will post a comment if I come across anything interesting. :)
P.S.   I am currently leaning towards something like spin waves being the most likely explanation, if the OU effect is real.
I have tests planned to pursue this line of thinking further.
itsu
Quote from: kolbacict on March 03, 2016, 08:48:13 AM
may be МБГО,МБГЧ?
At  "ELECMENTS13",   here:   http://stores.ebay.nl/ELECMENTS13
Itsu
John.K1
Quote from: Void on March 03, 2016, 10:06:33 AM
Hi Void. It looks like we are on the same wave :)  I am also in the process of learning. I have made three identical small Tesla coils and study the effects of transmitter Vs receiver.
Did you start to build special antenna yet? ;) (ferrite rods in circle around the former and some turns of wire)  -Some document I found interesting below ;)
Itsu- very nice finding - I have already ordered some stuff from that page:)  Just couldn't resist :)
