MenofFather
Quote from: Hoppy on May 07, 2013, 06:30:02 AM
Thanks, but what about the other white wire / cable laying on the garden behind the demo table??
I not see other cabel. It is maybe same white cable. Или трещина на земле выглядит как кабель.
MenofFather
Quote from: Hoppy on May 07, 2013, 12:06:55 PM
Look at 0:46 on: http://www.youtube.com/watch?v=v_2rinvpvrM
The wire / cable is laying under some vegetation on the garden, not on the concrete slab. The camera shot is very brief.
Is not cabel can be, but something for garden. Какая нибудь безделушка ,чтоб придержать парник и так далее.
Hoppy
Quote from: MenofFather on May 07, 2013, 03:11:14 PM
Maybe, maybe not.
Может да, может нет.
NickZ
   T-1000, Verpies, and All:
   I think that we really need to focus on what is making these devices work.  Let's just forget about the voltage source, inverter, and first rectifier, for now. As well as the feed back coil, cap, and second inverter. As these are not what is making this device produce an unconventional output. So, what is left? That is what we need to look into...
  All the self runners are using some kind of feed-back path to continue to run, that is the self runners mode of operation. But, that is not what causes the much higher output, from a very small input.
  On the SR 193 video the guy is showing something very interesting, not shown anywhere else. Which is, how the voltage on his power supply drops very fast, as the light bulb in the cardboard box is first lit up.  What this is indicating to me, is that, the output from the PS has dropped to 0 volts, 0 amps. Right? And he then disconnect it, and shorts the 4700 uF start cap. Then shows that small, silent spark gap.
Ok, so this is some proof that there is something unconventional going on here.  What is it??? That is the billion dollar question...
  You guys have been at this a LONG time, so, I'm requesting your help, as well as anyone else that is not chasing wild geese.
  My feeling is that  the center tapped primary coil with reversed polarity, be it on the yoke, or any other core, is part of the trick. Ferrite is NOT needed. Possibly even the primary being center tapped is not needed. As some are showing using the copper tube as the primary.
Possibly the 5 uF  AC run cap on the yoke circuit is acting as a spark gap, this I'm fairly sure of, there may also be needed a diode there, on that circuit. Then, what is happening at the big air coil? Everything there would be working as in normal inductance mode, even though the big secondary coil is going from the ground connection to the bulbs, that in itself is NOT a big eye opener. EXCEPT, for that choke and cap circuit in isolation, in the center of it with the aluminum sheeting, next to it.  Hendershot style.
Verpies,  come on, you can figure this out, It's not rocket science, a kid can and has done it.  So....
  Please help!
