0 Members and 148 Guests are viewing this topic.
Void
Quote from: John.K1 on March 03, 2016, 01:41:17 PM
Hi Void. It looks like we are on the same wave :)  I am also in the process of learning. I have made three identical small Tesla coils and study the effects of transmitter Vs receiver.
Did you start to build special antenna yet? ;) (ferrite rods in circle around the former and some turns of wire)  -Some document I found interesting below ;)
Hi John.k1. The spin wave theory is actually something different from scalar/longitudinal waves theory, but
scalar waves is another possibility I am considering. Thanks for the document from Meyl. I am familiar with
his stuff. The problem for me with professor Meyl, is he didn't seem to put much importance on the measurement
procedure when he claimed that the two tesla coil setup could produce OU. That raises some doubts about
his claims about OU in my mind, as we all know that the measurement procedure in regards to claims of OU is often
where OU claims fall apart. :) Something interesting that Meyl stated is that he said that there were two resonant
frequencies in the pancake tesla coils that Meyl could drive the coils at, but only one of the resonant frequencies
gave the effects he was interested in. If I remember right, I think it was the higher resonant frequency that
he said to use to get the right effect.
I personally think for all the devices Akula has shown, that it seems something along the lines of NMR or spin waves
or a similar type of effect would best fit as a potential explanation.
Spin waves are described in Wikipedia as:
"propagating disturbances in the ordering of magnetic materials."
An engineer named George Bugh has informally researched spin waves and has put forth the hypothesis that spin waves may account
for the over unity effect seen in certain claimed OU generators. It seems to possibly fit as an explanation for how Akula can supposedly
get an OU effect out of the various device configurations he has shown. The general idea is that magnetically pulsing certain types
of materials may release excess energy under the right conditions. Not just any type of ferrite or other material may work however.
You may have to find just the right type of ferrite or iron, etc.
George Bugh has some videos on spin waves here, in case anyone is interested:
https://www.youtube.com/user/narivasant/videos
Keep us posted if you find anything interesting with your tesla coil experiments. :)
John.K1
Hi void- Is the spin wave and spin field the same think?  I guess you are aware of the experiment by using special antenna :  http://www.zen22142.zen.co.uk/Media/fsi.htm
It is next think I want to try. I have many ferrite rods ready, just not sure what to do with all that  :). The ferite should not to be thick, otherwise you will get some sort of hysteresis. This brings me to an idea - what about to use a very skinny "painted" stripes made of black sand?
I was listening E. Dollard this week - eccentric person- but some things he talks about are fascinating. What attracted my attention was the information about the modulation of the statick HV field- and you will end up with very high magnetic field- Something not far to what Ruslan says, what Romanov says etc..
itsu
To show you the cycling effect when i loopback the 24V PS to the input 24V battery i made the below video.
Both the PS as the Battery have a big diode to prevent any of the 2 to charge the other.
I think it must be some interference / difference between the 2 DC voltage levels which is causing this cycling.
Probing the 24V from the battery (after the diode) does not show anything abnormal other then the some cyclic pulses, see screenshot.
I also show you on a spectrum analyzer the spectrum generated by the Yoke/TL494 system when in resonance and when not.
It seems that it generates a base signal around 14.3MHz  :o and when in resonance (or just below or above it) a lot of HF noise up till 50MHz  :(
Normally you would not be able to hear that, but i think it is the source of the hissing sound (via Low Frequency Detection) we hear coming from the TL494/yoke.
Video here: https://www.youtube.com/watch?v=Z4UYBrmh_OA
Itsu
Dog-One
Quote from: itsu on March 03, 2016, 04:42:38 PM
I think the cycling is due to the lack of sufficient amperage for the power supply to drive much of anything.  So once it's output voltage comes up, it immediately tries to take the load, dies and the battery resumes powering the system.  If you connected the power supply output to a pair of 12 volt bulbs connected in series, I'm pretty sure you would see the same thing.
Now that is interesting.  I would not have guessed there would be so much high frequency radiation going on.  It appears pretty strong too.  Very surprising.
T-1000
Itsu
Hi itsu,
I got some quick questions:
Why you are using separate battery for +12V power input to the electronics and not voltage stabilizer as in Oleg's schematic? This is making another loop for the kicks coming from the coil back over that battery...
Can you show what is the voltage directly out of looped power supply without diodes and on the battery side?
The fluctuations seems are due voltage difference between output of the battery and the looped power supply.
Cheers!
