0 Members and 212 Guests are viewing this topic.
Hoppy
Quote from: NickZ on March 10, 2016, 10:40:33 AM
  Why not continue with what has been shown to work, instead of second guessing the outcome of this unproven clamping system with the Akula/Ruslan devices?  Seams like a long derailment of the Ruslan type of replication.
I do not consider that the unclamped system of working is proven yet to give a self-running device, at least not by anyone on this forum. I assume that self-running is what you mean by proven? Its not as if a lot of work has not been done using the unclamped yoke winding, so surely it does not hurt to try out alternatives given no successs to-date.
Edit : If you mean proven by which arrangement gives max lamp brightness, then we have no proven benchmark to say that any given lamp brightness under test is an indicator that we are going in the right direction for a self-running system.
verpies
Quote from: NickZ on March 10, 2016, 10:45:33 AM
Really?
Yes, MOSFETs are not  being damaged by overvoltages between their drain & source terminals and the energy contained in these spikes is not being wasted as heat.
And where is the proof of that, in relation to the current tests?
What current tests?
Dog-One
Quote from: verpies on March 10, 2016, 11:21:41 AM
That's pretty hard to argue against IMHO.
If you want a self-runner, it will not hurt one bit to minimize power draw of the push-pull system.  You must hit unity before you can attempt overunity.  Verpies has likely put us one step closer.  Seems he is due a thank you or two.  I'm not seeing any other highly qualified engineers helping us here, every step of the way. for free I might add.
T-1000
The aim here is not to get the stuff like mosfet ringing out of the way. The Oleg circuit was used in Ruslan replication and even it is not perfect, still working to achieve self runner.
So question is where you guys are heading as it is not for trying achieve unusual effects with that time spent.
Something to think about..
Jeg
@Verpies
I checked again my cables and everything seem to be ok. But the voltage across the electrolytic cap which is connected to drain, is only that of the power supply. 24V. I will swap again my primaries in case i miss something.
The hurt of the system is that push pull. Making it reliable with less consumption while operating should be an aim for every experimenter.
