NickZ
  Quote from Void.
   I will see if I can find some time to do some experiments with this sort of setup over the next month or so. I am also interested in trying this out".
  That, would be swell.  I understand what you are saying, but, I will have to leave the frequency adjustment for those who have the needed equipment and tune-able frequency driver, that you mention.
  I have a 65 watt Cfl bulb driver, 110v, and unknown amp circuit that I can use, that I had previously shown a picture of. And I can also adjust frequencies using ferrite rods, magnets, and different winding counts, etz... But, can't just go buy various specs of AC caps, that may or may not work, to test out. Therefore what is needed, in my case, is a diagram with exact wire type, wire count, cap specs, and wiring diagram.  In the mean time, I'm doing what I can with what I have, and as mentioned previouly, no budget to work with, although I do have some discarded stuff that I can use. As my lab is my kitchen table, as Akula's is a small table in the corner of a room, I will do all I can with what I have and can obtain.
The trick is to obtain more out than in, while using or harvesting a magnetic current, that may possibly be different than anything we have previously worked with, like cold electricity, instead of hot dangerous or radioactive stuff. And after viewing the SR 193 video, again, I'm more convinced that it may really be possible.
  Thanks again, your contributions are much appreciated.
        Nick
NickZ
  quote:
  " You would have to set the frequency of the transistor driver circuit to run right at the resonant frequency of the series resonant primary circuit."
  Ok, I get that. Maybe the transistor, or drive circuit output, can also be frequency tuned by using an AC wall dimmer, along with variable capacitor from a radio, etz... and the light output from the leds (that I use on top of the small inductors) can be used as indicator lights, which can help to tune for the higher output.
Just a thought.
Otherwise, I know that this may all be like trying to find a radio station, on a radio that has no tuning knob.
  EDIT: After I posted the comments above, I found this in another forum. It is from a Tariel Kapanadze patent, and I thought that it would also fit in well right here:
verpies
Quote from: Hoppy on May 07, 2013, 02:00:27 PM
To recap then, with the various interesting possibilities:
1) The real McCoy (with MIB on their way!).
2) Faked with a multi-core black cable with hidden connections to the white cable going to the house.
3) Faked using a partially hidden 'X' wire run almost out of sight along the earth in the garden close to the concrete slab.
4) Faked using a one-wire transmission system.
5) Faked with large batteries hidden in those large plastic boxes.
NickZ
  Well then, with that overwhelming evidence, it looks like you guys have more than enough proof to start your own thread now.
  So that the people who would really like to move along and further advance on these threads, can do so without any more negative, disruptive, and ludicrous comments. Your true intentions must be now just to troll.
So it seams...
                                               "Don't feed the TROLLS"
    New thread:
   "ALL FAKE KAPANADZE REPLICATIONS".
NickZ
 Quote: from Void:
The question I would have is, is that aluminum sheeting connected to anything such as another coil, or is it just placed in there with no connection? Without having more specific details I think the best you could do there is experiment with a few different ways to connect the aluminum sheeting in, and compare to leaving it unconnected."
  That is what I've been doing, and will continue to do so. The hand drawn diagram is showing that choke by itself, not connected to anything other than the cap. But, having the right cap to work with is not easy for me, as I have no idea which one may work. I have tried several that I have on had, but so far, no cigar. That diagram was made for the first (or older) replication. But, I don't have any AC caps, other than start caps, yet, and they don't work. This I've proven to myself.
  I have the yoke wound in the same direction, not opposing winds, which I will correct today.
  It looks to me that the effect generation is due to magnetic energy. which will not follow the same normal induction, transformer, laws. And will possibly NOT shock, as well. I hope. Just look how in the replications they are showing these guys touching even the spark gap, or any part of the circuit. That should be an eye opener.
I'd like to see someone do that with an x-wire or batteries, and make 1000 watts of bulbs light, then touch the spark gap. Ha!
  Void, do you understand Russian?  I wish that I did...
