0 Members and 141 Guests are viewing this topic.
Void
Itsu:
Interesting to see the 100 MHz spectrum for the primary winding on your yoke.
You have a very nice spectrum analyzer there. As Verpies mentioned, varying impedance mismatches
through the frequency range may be affecting the results, but it is still interesting to see.
Jeg:
Good work. I suspect any small ringing or spikes on the gate or drain signals is probably
no so critical, except in the case where it might potentially lead to component failure. Otherwise a little
ringing or some switching spikes is probably OK, considering that Akula didn't seem to go to
too much trouble in that area.
We also probably need to watch out for any high voltage spikes feeding back from the tesla coil, once that part
of the circuitry is made active. :)
Jeg
Hi Void
Yes I guess there is not any problem for little ringing considering a self running operation. It is just a matter of self satisfaction ;D
NickZ
     Jeg:
          Looks very nice, and neat.
          Maybe use two 12v batteries, if you can, instead of the PS.
          What kind of earth ground are you using?
Jeg
Hi Nick
I have plant in my garden a copper pipe just for the experiments.
For testing my push pull's operation I don't need batteries. Perhaps at a later stage if there is any suspicion of ground loops.
NickZ
  Jeg: Ok, thanks for the reply.
   The reason I mentioned about the batteries, is because I notice some stray AC inductance on anything that's connected to my PS, even with adequate grounding. Which can at times also affect the signals read on a scope.
   Both my scope and PS are using the same AC ground from the grid.
   The earth ground is also very important, my 5 meter ground line, does nothing.  The 37 meter ground line into my water well does. But, it all depends on resonance, without proper resonance of the circuits, the ground lines don't do anything, or very little.
   Good luck with your circuits.  Looking good...
