0 Members and 41 Guests are viewing this topic.
Void
Quote from: NickZ on May 08, 2013, 01:09:41 AM
After I posted the comments above, I found this in another forum. It is from a Tariel Kapanadze patent, and I thought that it would also fit in well right here:
It is common practice in many patent applications to write about the device and how it works in very obscure terms, to make it hard for people to figure out exactly how to replicate the device. This also seems to have been done in the Kapanadze patent applications. I can't make out a whole lot out of what is said in the Kapanadze patents applications, although I should probably read through them again and see if can get at least some idea of how his devices are supposed to work. It is mostly indecipherable to me however. :)
Void
Quote from: NickZ on May 08, 2013, 11:36:03 AM
That is what I've been doing, and will continue to do so. The hand drawn diagram is showing that choke by itself, not connected to anything other than the cap. But, having the right cap to work with is not easy for me, as I have no idea which one may work. I have tried several that I have on had, but so far, no cigar. That diagram was made for the first (or older) replication. But, I don't have any AC caps, other than start caps, yet, and they don't work. This I've proven to myself.
  I have the yoke wound in the same direction, not opposing winds, which I will correct today.
  It looks to me that the effect generation is due to magnetic energy. which will not follow the same normal induction, transformer, laws. And will possibly NOT shock, as well. I hope. Just look how in the replications they are showing these guys touching even the spark gap, or any part of the circuit. That should be an eye opener.
I'd like to see someone do that with an x-wire or batteries, and make 1000 watts of bulbs light, then touch the spark gap. Ha!
  Void, do you understand Russian?  I wish that I did...
For choosing the caps for the primary circuit and choke tank circuit, you want caps that are non-polarized and which have a high enough voltage rating for the voltage they will have on them. For the choke tank circuit arrangement, you may need a cap with a voltage rating in the kilovolts area. It just depends on high the voltage is going to be on the cap.
You also would want caps that have a high current rating (low ESR). The second requirement if you are aiming for a specific resonant frequency is to choose a capacitance value that will give the desired resonant frequency when connected in to whatever coil or coils the capacitor will be connected to. You can use an inductance meter to measure the inductance value of the coil that the cap will be connected to, and then use the LC resonance formula to determine the approximate value of capacitance you will need to give the resonant frequency you want. You will probably still have to do some adjustment to the coil windings to get the resonant frequency right on. There are online LC resonant frequency calculators such as this:
http://www.1728.org/resfreq.htm
Unfortunately, I don't speak Russian. The following phrases should help though:
Да.
Нет.
Не берите в голову.
Капанадзе
катушка
дроссель
конденсатор
лампочка
Посмотрите, лампочка освещения.
Где водка?
Давайте выпьем водки!
на здоровые!
Grumage
Dear NickZ.
I have been following this thread quite closely of late because there are many similarities to the devices we are currently working on.
I DO have to agree with the comments that Void has recently made. One of the most important "pieces of kit" you will need to persue any of these projects is an LCR meter.
I know very well they are expensive, it took me two years to save for one. and believe it or not it was imported from the USA!! But for finding resonance easily I'm afraid you will need to get one.
I obtained most of my "kit" from a local training school. I went in "cap in hand" and explained what I was doing, but don't mention Free energy!! And believe it or not they gave me a scope and a frequency counter!! So give a few places a ring, you never know?
BTW this is the site I visit for LC resonance calcs........http://www.whatcircuits.com/lc-resonance-frequency-calculator/
All the best, Grum.
NickZ
  Void:
   Read the TK patent, again,  looking for the intention of what words may not be able to clearly explain.
   It is saying, there is an individual power supply, is providing power to the first coil, which alters this given electrical energy into magnetic energy, by its turned interaction with the second coil. The frequency is adjusted by some "frequency adjusters", and then converted from the input electric power source to magnetic energy, which is then reconverted by the second "adjuster" back to electric energy, to be used.
Two coils are needed, along with two frequency adjusters.
This does not cover the feed-back path, until possibly later on.
   This is what most of the self running device replicators have been saying, in their own way. Although possibly none of them are going to just freely give that secret up, of exactly HOW its done, in all it's details. As the consequences can be, well, unknown, at best. Most are trying to make a buck at this, which I can't blame. Not a bad idea...
  I had thought that I had made a mistake in my yoke coil winding direction, but on further in inspection, its was made correctly,  and is of opposing winds. I'll continue to work on this tonight, if possible.
NickZ
   Grum:
   Thanks for the info, good to hear from you. Although I do appreciate your ideas and information, I am not able to follow through with it. Someday these things may come to me in any case.
I'm good at finding my way in the dark, with my heart guiding my way, and can find my way even in the worst storms.  But, for now, I must find a horse that I can ride. As Dr. Stiffler once recommended to me.
  As you can see from my pictures, I've done quite a bit, while spending, well, Zilch.
  I will upload some more pics and videos, as soon as I can find my camera to pc cable, which is lost in my house.
  Please, don't give up on your project, we all need to get onto the real deal here, as this is not just too good to be true. It is true, and not to be ignored. Mark my works... I am a permanent fixture, not going anywhere, you'll see.
  I'll return to the other thread, when ever they stop peddling fake wares, as I can't deal with that, although they seam to get around.
                               What goes around, comes around...
