0 Members and 228 Guests are viewing this topic.
stivep
Quote from: verpies on March 13, 2016, 10:24:45 PM
My question referred to the asymmetry of signals between two identical MOSFETs - not the asymmetry of the architecture between drains and sources of MOSFETs.
when you do not have symmetry ( paired  properties) that it is hard to ask for symmetry in signals .
The  additional consideration is  impedance symmetry.
Presence of  reactances  changes with not only frequency but with shape of the input signal  processed independently.
e.g. square wave is  made out of http://www.mathworks.com/help/matlab/examples/square-wave-from-sine-waves.html?requestedDomain=www.mathworks.com
there you have it, when  you  average component  harmonics
in square wave the top is DC and what  is significant is leading edge and falling  edge. (AC) There are important harmonic components forming the edges. So in the bridge mode when you have distribution of the signals individual impedances of interacting sine waves with its newly created reactances  matters.(  identical distribution is  expected)
Wesley
hartiberlin
Quote from: justawatt on March 13, 2016, 01:06:42 PM
hi everyone
check out this circuit and see the video link
maybe this could be the last thing we can try to get free energy.
the video does not belong to me.
But i have made circuit based on the video ,i would like some one to try this circuit.
https://www.youtube.com/watch?v=5K3HrhH5Qrs
https://www.youtube.com/watch?v=RUF7eJAOjF4
I think the circuit diagram on this is wrong, as it does not need a ground
and it seems it just uses only 2 Teslacoils in some kind of oscillator circuit and
the battery is only delivering probably not much more than 100 Watts, as judging from
when  connecting the cables and the arc that is involved at this moment...
So below the white towel are probably some transistors to get these 2 Teslacoils oscillating
with the higher turn coils and the 2 x 6 Windings copper coils will just be the
output coils probably put in series via the standing blue electrolytic cap...
So it seems to be a power amplificator circuit, maybe on the phase shift of the 2 x 6 winding copper
coils always being maybe 90 degrees out of phase, so they do not drag each other down, so this oscillator
maybe a Lenz law violator...
As I find this device very easy to build and also does not seem to need a ground cable, this could also be used for
mobile applications like cars or electric bikes, etc...
So it is a very interesting device and probably easily to replicate...
Regards, Stefan.
stivep
That was  some time ago when I introduced  electrostatic pump theory.
It was working based on phenomena of electron inertia.\
The mass of electron is small but that mass while is moving  in conductor creates significant  heat.
In series of impulses electron does not stop in the intervals  between the pulses.
for that I foresee ground to be essential.
However ground plane antenna antenna works with its artificial  ground at 10floor of the building and that is sufficient size metal plate that this antenna is standing at.  for car  FM antenna the counterpoise is the metal body of the car. In some of the applications there is small tuning resonance circuit  between  metal body and antenna.
The theory relates to electrons flow due to  difference of potential from the ground to the device.
There is coil ( receiving coil)on the side that is  coupled in near field to the coil that is connected  between ground and the end destination  of the electron flow.
the ratio between that coil and receiving coil is up to us to decide.
At the  receiving coil  there is capacitor in parallel that is creating tunned circuit to resonate with the first coil.
part of the energy flow from the ground.
the missing part of that theory is the mechanism of recovery of energy used by the load vs energy  sustaining that pull(  HV potential)
In theory that would be no problem to use ionosphere /earth  potential difference and put our load on its way.
I have made analogy that car that pushed by 15  15years old girls after the wile requires 1 girl to push the car and then only 1 finger of  that girl to sustain the motion and compensate the losses.
I have  made analogy   to person trying to suck  gasoline from the car to the container  using flexible tubing.
The first he is introducing initiating force with his mouth  and that gravity does the rest.
So missing part of that theory is actually  me pointing at additional force that sustain device to pull electrons from the ground
This is part of it:
https://youtu.be/GnE1fjVANS8?t=516
and here is the rest
https://youtu.be/GnE1fjVANS8?t=650
but mechanism of that phenomena must contain the same set of elements ( in different form) as the example with the fuel "pumped" from the car.
Wesley
T-1000
Hello,
For the phenomena Wesley (stivep) is describing "the right moment" for high voltage spike to go through over capacitive  link to the ground seems is on the peak of current in the coil - https://youtu.be/Wt68ehFYVs4?t=16s
Bearing in mind about the support of high tension electrical field spike which do not require much amount of energy to sustain from the mutual power amplification effect being created - that may be root fundamental in Kapanadze style device.
We shall see if we can reproduce that in ongoing replication...
Cheers!
itsu
Quote from: verpies on March 13, 2016, 09:58:07 PM
The oscillations are so asymmetrical between the two MOSFETs !!!
What causes so much asymmetry horizontally & vertically ?
Yeah, i noticed that to, and tripple checking on the new toroid windings (first without the 4 turn secondary, later with it) did not show any wrong wiring.
I traced it back to the gates, the yellow MOSFET gate has these oscillations, the blue not, but is shows on both outputs.
Need to further stiffen up the driver voltage (12V) i guess.
It could probably be the cause of the oscillations with the yoke loss-less clamp setup to
Itsu
