0 Members and 64 Guests are viewing this topic.
ramset
Wesley
Have you ever heard of this man or about this crazy simple experiment in 2001 ?
http://www.energeticforum.com/renewable-energy/20419-hawkings-generator.html
Chet
Thanks Grandma
Dog-One
Quote from: T-1000 on March 14, 2016, 05:25:04 AM
For the phenomena Wesley (stivep) is describing "the right moment" for high voltage spike to go through over capacitive  link to the ground seems is on the peak of current in the coil - https://youtu.be/Wt68ehFYVs4?t=16s
Bearing in mind about the support of high tension electrical field spike which do not require much amount of energy to sustain from the mutual power amplification effect being created - that may be root fundamental in Kapanadze style device.
In that particular video Ruslan demonstrates a CRT yoke is not needed.  He is clearly using an E-core to build current in the induction heater coil.  This should eliminate any factor of the yoke being necessary for OU operation.
This phenomena appears to me to be a case of reactive power amplification.  You have an idle condition where voltage and current is 90 degrees out of phase and you introduce an external high voltage source that is in-phase with the current.  This creates a condition where you now have real power that can be extracted.  Somehow the external voltage source is mixing with the available current in the tank circuit.  I think two things must be happening here.  We are getting electrostatic induction into the grenade coil from the external high voltage source AND we are getting magnetic induction into the external high voltage coil from the induction heater coil.  Both are happening simultaneously.
How can this work?
Two circuits:
   1st inductive -- voltage leading current
   2nd capacitive -- current leading voltage
When brought together and mixed in the grenade coil, the phase mis-alignment of each circuit is compensated by the other, creating two conditions of real power, one which we draw out to power the load and the other compensated by equalizing to earth ground.  Each circuit only "feels" its reactive component as would happen in any properly tuned tank circuit.  When mixed though, there is real power to be extracted since two conditions exist where voltage and current are in-phase.
I've thought many hours about this and see no other way this could work.  It's just a matter of getting each circuit tuned with the common mixing point (grenade or Dally coil).  We should be able to attack each circuit with its partner shut down and observe the proper wave forms and phase alignment.  Then we turn on both circuits; magic happens.
Void
Quote from: justawatt on March 13, 2016, 01:06:42 PM
hi everyone
check out this circuit and see the video link
maybe this could be the last thing we can try to get free energy.
the video does not belong to me.
But i have made circuit based on the video ,i would like some one to try this circuit.
Hi justawatt. Welcome to the forum. You didn't mention where you got that schematic drawing from.
The person who made the videos you linked to covered up the circuitry and also taped over the
top of the blue vertical tube. They obviously don't want people to know the details of what they are doing.
I guess someone was just guessing based on what they see in the videos when they made that schematic?
Regarding the schematic you posted,  whatever is in that blue vertical tube is not likely at all an electrolytic capacitor.
There also does not appear to be any earth ground wire connected to the circuit in the video, but some of the schematic
otherwise looks like it might possibly be potentially close to the rest of the circuit layout which we can see in the video.
Can you provide some specific details about what is the origin of that schematic and what it is based on?
You said you built the circuit. What are your results with your testing?
All the best...
Void
Hi Dog-one. Yes, it would seem that this is a possibility for how this sort of circuit might work,
and something I have been conducting various experiments with as well. I still
don't see anything too earth shattering, so far at least. :)
NickZ
   Justawatt:
   I don't see the part where the battery is disconnected from the circuit. So, not a self runner, like is being mentioned in the tittle of the video. It's just an inverter.  Or what?
   These videos are showing something we'll never know how it was done, or what was done. No schematic of the driver circuit, either. So, How could you replicate it, not knowing the basic layout and circuitry?
   And I'll bet that your result were....  Not self running...
