0 Members and 42 Guests are viewing this topic.
Void
Quote from: NickZ on May 08, 2013, 05:43:41 PM
  Void:
   Read the TK patent, again,  looking for the intention of what words may not be able to clearly explain.
   It is saying, there is an individual power supply, is providing power to the first coil, which alters this given electrical energy into magnetic energy, by its turned interaction with the second coil. The frequency is adjusted by some "frequency adjusters", and then converted from the input electric power source to magnetic energy, which is then reconverted by the second "adjuster" back to electric energy, to be used.
Two coils are needed, along with two frequency adjusters.
This does not cover the feed-back path, until possibly later on.
   This is what most of the self running device replicators have been saying, in their own way. Although possibly none of them are going to just freely give that secret up, of exactly HOW its done, in all it's details. As the consequences can be, well, unknown, at best. Most are trying to make a buck at this, which I can't blame. Not a bad idea...
  I had thought that I had made a mistake in my yoke coil winding direction, but on further in inspection, its was made correctly,  and is of opposing winds. I'll continue to work on this tonight, if possible.
Well, as far as converting electrical energy to magnetic energy, that's what a coil does. You apply a voltage and current flows, and a magnetic field builds up around the coil. When you apply an AC voltage to the coil, the magnetic field builds up and collapses in sync with the AC current. Mr. Kapanadze seems to have left out many important details in his patent application. I will read through his patent applications again on the weekend and see if I can make more sense of them. I did some more testing and I see nothing special at all with the Akula series resonance primary circuit arrangement. If there is a secret to what Akula was doing, it is likely completely hidden inside that big coil pipe. Maybe something to do with the exact way he has made and connected in that choke coil, or something with the way the aluminum sheeting is used, or a combination of the two. Since he mentioned Hendershot, it may be that the aluminum sheeting in conjunction with the choke is at the heart of it, but there is no way to know for sure how he connected them in, and how he tuned it.   Since we don't know what he did there, trying to replicate is pretty tough. :)
NickZ
  Looks like this is not something that can be figured out by reading a patent, or figuring it out from what is known, but possibly from what is not known, instead. Or we would have gotten it already over a 100 years ago. The fact that we see that they are not getting shocked, is something not "normal". Or that you can obtain such a big output from such a tiny spark (spark gap), either.  But, sooner or later one of us will hit on it, and the rest can just copy it to the tee. This is not for the faint of heart, or short of patience.  If you wait long enough you'll just be able to buy it. But, I find the prospect of "hitting on it" something thrilling, worth while, and pulling on me. But also possibly something that most of us will never see. There are other ways to "get there", also.
anandml
  Void:
@nickz One doubt Why Tk use inverter(12v to 220vac) in all his demonstrations. If he used inverter to adjust the frequency or get constant frequency along with output power
NickZ
 That may have something to do with it. But, SR 193 was able to do it using 12v, and 1 amp to start the device, or maybe also just with a 9v battery, also, like Kapanadze. Then after only a just few seconds can disconnect the source input, and it continues on, even with out using an inverter. So, the inverter may not be essential to its function, although Akula does use it.
  In the last translation of the newest Akula circuit, Wesley shows at minute 10.22, what he called another one of Akula's diagram, but it was not the hand drawn one, but another one showing only a single transistor and a much simpler circuit. That is the one I'd like to look at more closely, and am most interested in trying to replicate. If I can find it, because I can't read the one Wesley is showing.  If anyone has it, please upload it here.
Void
Quote from: NickZ on May 09, 2013, 02:59:44 AM
I think that schematic is the same schematic that was posted here previously as possibly the schematic for the chubinidze device. Stivep was showing schematics that were posted to this webpage, I believe:
http://vk.com/id23370372
Looks like schematics and videos posted from various sources on the net.
