0 Members and 45 Guests are viewing this topic.
NickZ
  Yes, that's right., Maybe the Chibinidze device is just a replication of Akula's specs.
   Here is a very clear view of the original Akula diagram, showing the values a bit better. And, showing the 5 uF, 600v AC cap connected in series with the yoke circuit. Last night I tried a start cap in parallel, but it didn't work, either. I'll try to find the right 5uF run cap, when I can.
    (http://realstrannik.ru/media/kunena/attachments/4743/img004.jpg)
  Notice also that he doesn't show any end connection at the bulb sign at the end of the big air coil. As well as the two caps just touching the air coil before it ends. None of that is conventional electrical circuits. No spark gap, either.
Void
Quote from: NickZ on May 09, 2013, 11:22:53 AM
Yes, that is the hand drawn schematic that I have been referring to. I thought you already had it and were referencing it, since it was posted previously. A couple of things. Do we really know that this schematic is from Akula? If so, how is it known that Akula created this schematic? The other thing is the schematic may have just been preliminary and not even tested yet. It may not be complete, or may not even work. Something to consider.
I am not sure what you mean about the bulb sign, as I don't  see any bulb symbol on the schematic. Do you mean the full wave bridge rectifier symbol on the output of the secondary coil? Another potential issue I have with this circuit is that if you wind the secondary with lots of turns and use lighter gauge wire such as magnet wire, the secondary will not be able to conduct very much current. I think I saw magnet wire as being used as the secondary in the previous Akula demo video. If that is the case then I can't see how a secondary wound with lighter gauge magnet wire could be used as the actual output coil that is connected to the bulbs. We don't know the turns count that was used on the secondary as well. A lot of unknowns in this circuit.
Void
Has anyone seen this video before? It is supposed to be a kapandze like self runner from what I can gather. I think the person who has this video posted on their youtube channel is not the person who made the video demo. There is a contact email address listed, and I think they are asking for money for the schematics. That of course sounds a lot like a scam, but I think the person who originally made the demo video is a different person than the person who posted the video, but I don't know who originally created the video, or where it originated from. Anyone have any info? Maybe this video has been discussed already somewhere.
Гениратор свободной энергии! Free energy generator
http://www.youtube.com/watch?v=QZzVb7CqnaM
NickZ
  I just thought to upload the Akula diagram because although we've seen it before, this last one is very clear and easy to read. I agree that we have no idea where it comes from, who actually drew it, or if it even works, as is.
   Ok, so the coil sign on the Akula diagram at the end of the secondary coil is then indicating a full wave rectifier, but no further connection from there to the bulbs or back to ground, or anywhere else. Again, not normal. But, It does work that way, as I've already tried it.
   MenofFather is guessing that the secondary coil is about 40 to 50 turns, of 6mm2 which I don't know what gauge that is, but it thick enough, and not mag wire.
  I've made my big secondary coil 43 turns, and 4 inch diameter. The resonator coil is 12 turns, and feed-back coil is also12 turns, all three coils are made from the same (green stranded insulated house wire), and both the two smaller coils are wound on top of the big 43 turn secondary coil. My choke former is about 2 inch wide by 6 inches long wound with the same green wire, and has 12 turns loosely wound with a start Ac fan start cap attached to it (for now). I'll try to upload a pic or two tonight to give you all a better idea of what I got going. It also has an aluminum liner on the inside of the big air core.
I can light a 60 watt bulb on 9v, and less than 1amp, to about 60% brightness, as is, now with no tuning done on it yet. Pulsed from my Joule Ringer 3.0 circuit, using a 5 inch ferrite rod core, and a  single TIP 3055 transistor, or similar one, with no other component on that pulse circuit. Just a single transistor, ferrite rod coil, which is then connected to the yoke.
  The video that you just posted I had not seen, but he has several videos out on YouTube, that I had seen, like the one below, from Feb. 2013, compared to the one you are mentioning, which is an updated one from April of this year. Showing a self running device.
http://www.youtube.com/watch?v=kL67lrRrQi8&NR=1&feature=endscreen
  Like I said before, there are way to many working replications for them all to be nothing but fakes. If just one of them is real, then we really need to figure out how and why it works.
   As soon as the Chinese get a hold of one that they can replicate, we'll be able to buy it from them off of Ebay, for less than we can build it ourselves.
Void
Quote from: NickZ on May 09, 2013, 04:12:54 PM
  I just thought to upload the Akula diagram because although we've seen it before, this last one is very clear and easy to read.  Ok, so the coil sign at the end of the secondary coil is then indicating a full wave rectifier, thanks.
  The video that you just posted I had not seen, but he has several videos out on YouTube, that I had seen, like the one below, from Feb., compared to the one you are mentioning, which I think is an updated one from April of this year. Showing a self running device.
Yes, you never know...
Thanks for the link. I don't think that is the same guy as in the video I posted though, as their voices sound different.
