0 Members and 406 Guests are viewing this topic.
magpwr
Quote from: Void on March 18, 2016, 04:35:27 AM
@Magpwr. How did you make out with your tests with your HV driver circuits?
Hope you didn't get a zap from that high voltage you are using...
hi void,
Glad you asked.No components destroyed as i test my circuit in high voltage.
I have finally figured out how Akula got around 32kv.This would cause the insulating layer of the 5cw/ccw wire at the ferrite rod to breakdown and spark is produced from ferrite rod."This is important"
Only small hint i gonna give for now it's definitely more than "100volts" needed for the so called kacher.
For the rest of you still playing with kiddy voltage like 24volts or less for kacher just forget it.
Geofusion did got somewhere around 32kv but looking at the video he did cheated on the kacher.He created extra long tesla coil to generate high voltage but it's definately no where near 1.7Mhz.
By doing that he was able to run at voltage around 12 or 24volts likely.
Nothing to criticize since i did l learned something from there previously.
But i am little disappointed since many seems to be struggling with pwm circuit.
All ringing for me was suppressed because i planned from the start to use nanocrystalline core.The choke toroid is important as well i
noticed there is ringing induced if i use any toroid other than nano crystalline core with 2 turns.1 turns approx 44uH.
I have already done my part to assist by previously uploading a UC3825N PWM circuit in youtube with 1.5Amps output but many of you folks still sticking with obsolete TL494 with 250mA output.
No skinny wires for toroid as i am using 4mm sq from pri and 28turns and 6mm sq for 3.5 turns.
That's all for now.
verpies
Quote from: Void on March 18, 2016, 03:48:35 AM
Wesley, many thanks! That was fast. :) You are a good man. I liked your "Bla bla bla" translations. That made me laugh. ;D
That amused me, too.
Quote from: Void on March 18, 2016, 03:48:35 AMI also got a laugh when that guy put the ground wire on his tongue. Maybe not such a good idea on a live circuit even if it is just a ground wire. ;D
Especially if they placed a hidden hot wire inside that silver braid that is purported to be a ground conductor only.
BTW: Metal braids are not cheap.  Try to buy some or cannibalize it out of a coaxial cable.
Void
Quote from: verpies on March 18, 2016, 10:18:07 AM
Hi Verpies. Anything is possible, but Kapanadze has allowed people to inspect the ground connection point, I believe.
For example, the group that went over and who made that earlier aquarium video were allowed to inspect the ground
connection point, and they seemed to be satisfied that there was no live connection there. Pricey or not (when new),
they may well have used braided ground wire to show that they could touch the wire and lay it on the cement without
there being any shocks or shorts to ground. For those who have already made up their mind, no matter what is shown
in a video it will still be assumed to be fake. It is a given that any free energy video could be fake, but Wesley as well
as the other group we know of have seen it operate close up and could not find any tricks. It still doesn't mean that it wasn't
a trick, but unless the people who inspected the ground connection point were pretty dumb, it would seem the ground
connection point probably wasn't live. :)
@Magpwr. Well, Akula seems to have just used a TL-494 and a TV yoke core, and he seemed to do OK with that,
assuming it wasn't a fake. :)  Kapanadze's demo from May 2015 has a layout of a tesla coil and 'receiver coil' that
is similar to the layout that Akula came out with, although Kapanadze's 'receiver coil' looks different in this case,
but he could well have added some extra 'bobbins' in there just to try to throw people off. :) I do wonder why
Kapanadze's device layout for his May 2015 demo video looks so similar to Akula's second self runner layout...
I hadn't seen Kapanadze use a a layout quite like that previously. With Kapanadze, assuming his devices may be legit,
you just don't know what are essential components and what is just placed there as decoys to try to throw
people off. :)
verpies
Quote from: Void on March 18, 2016, 12:37:14 PM
There was no close inspection of the "ground" connection on this video.
But, there is another piece of evidence, that is against the hot/live wire inside the braid (or Litz'ed braid).
Namely, that clamp-on meter would read zero Amps, if both the hot wire and return wire were inside the meter's jaws.
That leaves the possibility of a hot wire being surreptitiously connected on the load side somewhere.  The video does not reveal that...
...or the device is really working as advertised.
NickZ
  Yup, another black box video.  But, he's still the man, with the unbeaten output.
  And not one person knows how it's done,yet, so some will guess that it's a fake.  Well, I don't.
   The dual sparkplugs spark gap going to the copper tube primary is one thing to notice. Might be good to try that on the Akula/Ruslan devices. However, That may be how he avoids having to use most of the otherwise needed electronic components that may not withstand the HV pulses.
   Tariel's device makes no noticeable ringing noise, as it has no ferrite yoke. And that is what normally makes the ringing sound.
But, that is somewhat strange, at that mentioned 200khz frequency. There's no ringing at all...
  What I picked up on my audio spectrum analyzer on Tariel's device is around 7khz. But, there is a lot of room noise, fan running etz... so it's really hard to tell with all that noise, and especially with no ringing coming out of the device, to be able to analyze it properly.
   Wesley:  Thanks for that translation.
