0 Members and 132 Guests are viewing this topic.
Void
I am seeing some test results with at least some possible potential in my tests in the last
several weeks. I work very slowly however, so it could be weeks or even months before I can see
if it might pan out to anything worthwhile. It is easy to get off track, as it can be hard to figure
the best way to try to zero in on an effect when you don't really fully understand what is going on yet.
We'll see how it goes... ;) Chances are it won't pan out, as I've seen some interesting effects in the past
that didn't pan out to anything more after lots of in depth testing. :)
I suspect a few others here might also be seeing some test results with some possible potential as well.
Kapanadze had better hurry up and get his business dealings done before his secret leaks out for good,
although it probably won't be me who would leak out his secret without very good reason, as I would like to
see the old guy cash in on his invention before it is too late.  ;D
AlienGrey
Quote from: NickZ on March 18, 2016, 03:48:42 PM
  Justawatt:  Your posting that on the wrong thread. There's a thread for that.
I couldn't watch that video, too blurry,  made me dizzy.
   AlienGrey:  "someone said he is he a grave digger in his daytime job" ?
   Oh, ok, thanks, I wonder what he's been doing at night? Taking flamingo lessons, maybe.
Oh that's out of context! Justawatt point is not, Anyway in the circuit I watched it showed 2 A  at 240v that's 500W to light a light bulb  ;) ha Ha !
Tomtech29
Quote from: magpwr on March 18, 2016, 09:46:42 AM
hi void,
Glad you asked.No components destroyed as i test my circuit in high voltage.
I have finally figured out how Akula got around 32kv.This would cause the insulating layer of the 5cw/ccw wire at the ferrite rod to breakdown and spark is produced from ferrite rod."This is important"
Only small hint i gonna give for now it's definitely more than "100volts" needed for the so called kacher.
For the rest of you still playing with kiddy voltage like 24volts or less for kacher just forget it.
Geofusion did got somewhere around 32kv but looking at the video he did cheated on the kacher.He created extra long tesla coil to generate high voltage but it's definately no where near 1.7Mhz.
By doing that he was able to run at voltage around 12 or 24volts likely.
Nothing to criticize since i did l learned something from there previously.
But i am little disappointed since many seems to be struggling with pwm circuit.
All ringing for me was suppressed because i planned from the start to use nanocrystalline core.The choke toroid is important as well i
noticed there is ringing induced if i use any toroid other than nano crystalline core with 2 turns.1 turns approx 44uH.
I have already done my part to assist by previously uploading a UC3825N PWM circuit in youtube with 1.5Amps output but many of you folks still sticking with obsolete TL494 with 250mA output.
No skinny wires for toroid as i am using 4mm sq from pri and 28turns and 6mm sq for 3.5 turns.
That's all for now.
HI.
Now I have to disagree with you.Everyone on this forum did as much as he was able , we reached the threshold has not been exceeded
-the lack of information and support for developers.
what is your statement that the system is more efficient (mA) PWM?
The final effect is the same disappointment It is included in this set!:D
But we are still here in chat rooms,who knows if at all see the light of day this generator!
deceptive is this world for Mr. T Kapanadze Fear is no stranger there will be some who will buy and fall silent !
affair or all knowledge would go to the grave.
I would like to ask Akula or Ruslan how much gives this power induction heater?
(secondly it is to mix power with high voltage)
-four years have passed and no one replicated indicating the high efficiency not to mention the over performance?
magpwr
Quote from: Tomtech29 on March 19, 2016, 05:51:14 AM
HI.
hi Tomtech29,
When i started commenting in this topic around 2 years ago.I was hoping to find people whom are around the same caliber as i am.
But to date i am still finding people whom are still struggling with PWM circuit."Please don't tell me this basic PWM\snubber issue have been going on for 4 years in silence."
Let's not go into pll yet although i have no issue with it.
Yes there are members whom are indeed better than i am but i have not seen any circuits from them to date.What does this reveal."No clue what to do?"
But i do know "many" in here  for the free energy.No passion in Electronics or what so ever.
Anyway we are still better off than the Russian forum and i really appreciate people whom post youtube video of interest in here.
Maybe i shall wait for someone to impress me with their demo before i will reveal anything further.I was never stuck just closing in. :D
This free energy stuff is like the Dark side of science.
I do like to go for the most efficient components like Silicon Carbide Mosfet/diode or Nanocrystalline core.
Recently i just got myself a world smallest mains voltage to 24volts converter 400watt rated at around 92% efficiency."4kv isolated"
Yes it cost me nearly 200 usd.
Hoppy
This latest Kapanadze video is a nice one to dig into and it looks like TK's team have done some by digging a very possible 'X' cable into the ground to feed power to the device via the lamp array wires! Notice that after the lamp array mounting board is moved, the cable gets concealed. Its clear that after the Aqua2 video, the team had to eliminate calls of fake from the possibility of the earth lead carrying the mains power, by showing the clamp meter and lick test.
