0 Members and 112 Guests are viewing this topic.
tagor
Quote from: Void on March 22, 2016, 10:37:18 AM
Hi Tometech29. I think Fabrice Andre has not showed a self running device, and it is hard to tell
with what little he did show whether he has anything worth considering or not. I have not seen
anything further from him for several years now.
fabrice andre had nothing working , only bla bla bla
http://overunity.com/12770/le-refuge-de-fabrice-andre-et-ses-projets-surunitaires-ou-surnumeraires/msg476658/#msg476658
Void
Quote from: T-1000 on March 22, 2016, 11:41:21 AM
Hi all,
It is interesting to see how talks shifted quickly from the build to x-wires and speculation.
Did anyone here ever tried to find current resonance in grenade output (not P-P voltage) where there is not much of voltage but the current oscillation on almost shorted coil goes almost chaotic to the high frequency? This is a resonant spot akula and Ruslan was talking about and this is where you inject electrostatic pulse to amplify output...
Hi T-1000. I am conducting experiments pretty much daily related with trying to produce an OU effect
similar to what is claimed with the Kapanadze/Akula devices. I am certainly seeing some effects worth
investigating further, but I can't say I am seeing any cases of definite OU as of yet. It is one thing to consider
the theory/approach of how it might work, but quite another thing to get it to actually work to a level where
you can start considering that it might really be OU. I am not there yet. Still working on it... :)
Hoppy
Quote from: Void on March 22, 2016, 11:55:19 AM
Hi Hoppy. For certain no one reasonable expects you or anyone else to accept anything at face value,
and clearly that is not what I have been saying. I certainly don't accept anything at face value in this regard.
The bottom line is speculation is not evidence of anything. You can continue to speculate about such matters
all you like, but it really doesn't help anything except possibly to make you feel more comfortable with what you
believe.  :)
Its through conjecture that we are able to formulate ideas to motivate us into trying different experiments in an attempt to establish the truth of a claim in the absence of evidence supporting that claim. We clearly think differently.
T-1000
Quote from: Hoppy on March 22, 2016, 11:54:27 AM
A good mix is healthy for brain exercise.  ;)
Any ideas on how Ruslan / Akula circuits might achieve current resonance and chaotic HF?
Ruslan and also akula said is straight:
Attach 10 Ohm resistor to the grenade output coil and use inductor with generator attached to find current surge.
There will be spot when current will go "insane" and spike while there is not much voltage generated on the output.
Then step down input voltage and try again. Repeat until you are certain about specific resonant point. Then build generator to feed in same volage, frequency and duty cycle to the grenade.
Hoppy
Quote from: T-1000 on March 22, 2016, 12:22:51 PM
Thanks. This sounds like a ferroresonant approach using a saturated core to clip the output voltage, whilst drawing a heavy primary current. But we don't have a ferro core, or should we.??
