0 Members and 72 Guests are viewing this topic.
Jeg
Quote from: AlienGrey on March 22, 2016, 09:26:58 PM
I did one on a 1.5 ich pipe and it's 16 mhz so i think you will be very lucky at 10khz
You are right. There is not any noticeable rise at those so low KHz frequencies. It is just that when you hit the right Khz frequency, there will be a rise of higher MHz harmonics which are related to the wavelength. Then you know that you spot the right KHz frequency.
AlienGrey
Re device below is Grenade  it is made up of 37 meters or 2.5 conduit cable, at 38 meters long and your driving it with 19 meters of the same, to find freq its wavelength (cable length) which is found from Velocity (speed of light) over frequency. So 38 meters = about 8 megahertz and the 19 meters length works out to about 16 megahertz. FOR THE FULL WAVE !
Regards AG
I would  be inclined  to use 2.5 mm (50/0.2) a multi strand from RS, Maplin do it at about 1.80 so 40 meters at 2.0 would be 80 + 40 = a lot of money the copper free from Maplin is about 5.00 a meter ! Not sure about adding Vat.
The problem copper attenuates at HF 16 meg ect so it gets hot and doesn't conduct so well and might melt the PVC under load and could be a fire risk,  but I think I would get the thing working first !
Hoppy
Quote from: NickZ on March 22, 2016, 09:34:36 PM
  Hoppy:
   Good to hear that you're threatening to get the dust and cobwebs off the old coils, and start to build something.
Fakes, or no fakes.
   Which Vasmus video are you mussing over?
   Here's his personal hand drawn diagram, below.
   His coil system may be more complicated than the Akula/Ruslan devices, but his drivers don't seam to be as complicated as compared to Ruslan's newest 4000w rig.  Coils are easy to build, but, drivers that produce OU, not so easy to do.
Nick,
This one posted by Alien a few pages back: https://www.youtube.com/watch?v=PW7mwcLk9PM
AlienGrey
  Hoppy:
Fakes, or no fakes.
Note in the top right hand side he has drawn a CAP that's the earth environment, we live in a capacitor , L1 is TX L2 is RX the spiral is a coil pick up for internal power use of the system.
T-1000
Quote from: Void on March 22, 2016, 09:40:35 PM
Hi T-1000. I ran some tests by driving the inductor winding with a FET driven by
my function generator. I did not see anything unusual going on in the 10 kHz to 40 kHz
range or so. I used an 8.2 ohm power resistor across the grenade because that is what I had handy,
but all I see across the resistor on my scope is the switching waveform with some ringing. I did not see
any special frequency in that frequency range where there was any sudden bursts of current or
unusual spikes, or anything like that.
Hi Void,
Do you still see same ringing frequency on the wire with current pick-up transformer when shorting out resistor?
Also what frequency is on the ringing wave?
And the second step is to change into sine wave on inductor which would be close what you feed from series LC.
