0 Members and 1033 Guests are viewing this topic.
Hoppy
Quote from: AlienGrey on March 23, 2016, 07:40:25 AM
He shows you that donut device on the front left, it's all looped as a self-starter, it sounds like he has a coil driving a gravity neomagnet in a tube or a relay controlling a set of contacts perhaps with c and r for timing. Look on his forum !
A triac circuit is also shown switching the load in one of the videos posted by Void (thanks) above. The triac is fed with 500V pulses. Beyond that, I cannot make much sense of the circuit configuration of the overall complete device based on the rough diagrams drawn in the videos.
Hoppy
Quote from: NickZ on March 23, 2016, 11:17:32 AM
  Something does happen to improve the output when the ground line is connected, but there may be more to it than the supposed pumping effect.
Nick,
In your case, the earth has an effect on the circuit impedance through capacitive coupling to ground. Any increase in brightness is as a result of energy drawn from the power supply, not the ground. You can prove this to yourself by careful measurement.
NickZ
  It would seam so. However, my bulbs stayed on, but without the kick start from the induction circuit, that does not happen.
   I can't light even one bulb on the 12v wall adapter, by itself, or on some circuit.  So, there is something unusual happening there.  And as I'm looking for the "amplification effect", I can't let go by unnoticed. As that may be the first step towards self running. Or possibly how some guys can run 4000w worth of bulbs, and other things, from a simple Kacher's output. Like was shown in that one video.  As always,  if true.
GeoFusion
Hi Guyz  ;D
   Hi Void,
Maybe you could try to find current peak this way. I did it with a simple TL494 circuit and with a Halogen ( 12V car lightbulb)
could be any other incandescent around 7Watts too.
This is the link to my vid on my channel.
https://www.youtube.com/watch?v=SdYGq_jhmeg
Down here I have a diagram to show how it's connected.try it out.
It is for sure between 10khz -40Khz range. But..
Frequency will vary on all different capacitor you use in order to get the current peak.
Tune smoothly while turning the freq pot, sometimes it feels like you bearly moved the pot and you'll reach it.
don't have to mess around with Duty cycle here. ;)
Cheerz~
Hoppy
Quote from: NickZ on March 23, 2016, 12:22:54 PM
Nick,
In your case, the acid test, without getting deep into electronic principles and involved measuring to guide your thought process, which you don't appear to be happy to get into, is every time you make the slightest alteration to your circuit, simply to pull the plug on the power supplies running your device to see if the bulbs stay alight. If they do not extinguish, then you will know for sure that something unusual is happening. Otherwise, you will never know whether any strange effects you see are explainable by conventional electrical principles. This applies to the 'amplification effect' you refer to, as this may be visually perceived but without very careful measurement, it cannot be confirmed to be an overunity effect and even then, measurement error is all too common.
