0 Members and 249 Guests are viewing this topic.
T-1000
Quote from: skywalker66 on March 24, 2016, 04:57:00 AM
Maybe ground is need connected at one end of the grenade, T-1000 can tell if that is a must in that test.
If you look to grenade in same way as Tesla coil, when it hooked up to the circuit, the top layer wire will need ground connection. What is happening there between ground and coil still need to be found.
Quote from: verpies on March 24, 2016, 05:16:14 AM
The units are wrong implying that this frequency is constant.
It should be 26.5MHz per 1 Tesla.
...so at e.g. 0.5T the Larmour frequency would be 13.25MHz
Yes, which makes the "external fields that are generated in a laboratory" insignificant by comparison.
It is well known that the NMR frequncy in solid metals is subject to that strong internal field.  For example the internal field in bulk iron it is -33T which causes it to resonate around 45.5MHz up to +0.5T external field and decrease a little for stronger fields, which is opposite to what you'd see with iron atoms in e.g. ferric chloride.
You still get idea how to manipulate NMR frequency for causing strong magnetic field in induction on the output coil.
I just mentioned in this thread because still have thought about possible NMR happening in the copper wire on Kapanadze style devices and about other possibilities.
Cheers!
cheappower2012
To Hoppy
look at 3:39 to 3:46 the device starts up without
the 9v battery touching anything,you can hear the device startup
before the battery connects.Give me your opinion about this.
https://www.youtube.com/watch?v=Fw9o2pGGqGU
baudirenergie
Quote from: cheappower2012 on March 24, 2016, 06:08:05 AM
To Hoppy
In my opinion, that Video has a Problem with Audio synchronistion. Look at reflection of Light on elektrolytic capacitor, if he started the device. Best regards..
Hoppy
To Hoppy
Yes, it does appear to be the case. I have done some enhancements of the wire ends to see I can detect any stray stranding that could account for this but cannot see anything obvious, although the video is very grainy, so cannot be sure. At first I thought it could be possible that the sound track is out of synch with the video. If faking is the case, then it strongly suggests - as per my niggling feeling - that the noise / source of power is external from the demo board and being switched into the load wiring (hidden 'X'-wire into the lamp holder) manually by Vasmus and at the second switch-on he loses co-ordination between hands.
