0 Members and 288 Guests are viewing this topic.
Void
Quote from: Jeg on March 25, 2016, 02:20:02 PM
Hi Void
There is always the choice of not believing anything other than the raw experimental result. ;D
Hi Jeg. Yes, that was kind of my point. If something really works, then it works. We should be able to
demonstrate this to our self or to others if we wish, and beliefs really have nothing to do with it.
It either works or it doesn't. Belief wars based on "I believe this, you believe that, but my beliefs
are better than your beliefs", (yes, that what it often really boils down to) is pointless and contributes
nothing to free energy research. :)
Some thoughts about the quality of voltage and current. We know that current doesn't exist with out voltage. Current is always flowing from higher voltage potential to lower. What if our conventional devices work at lower potential levels than the earth itself? Would energy start to flow from outside to inside? Would we have a reverse to the losses that take place in a system? Would the heat be reversed to cold?
I have also considered this idea as well.
I don't know about circuits running cold, as I think it would still be electron current
in the scenario you described. Electron current would still be flowing from the
higher voltage potential to the lower voltage potential even if you drew current from the
earth to a lower voltage potential than the earth at the point you are located. Many things in the
universe are paired or coupled. If there is an opposite of electron current flow, such as say positron
current flow for example, or something along those lines, then maybe it would have a cooling effect
rather than a heating effect. A person just nevers knows what might be possible if they have
an open enough mind to take a careful look. :)
Regarding drawing current from the earth, it might make sense that if we can produce large negative
voltage pulses with respect to the earth, that we might be able to draw in (electron) current from
the earth. Whether this would turn out to be over unity is another thing altogether however. :)
P.S. This is actually one of my possible working theories to investigate regarding Kapanadze.
skywalker66
Quote from: Void on March 25, 2016, 03:07:30 PM
Hi Void !
That is in fact backwards. Electrons being negatively charged according conventional science,
a large enough positively voltage pulse with respect to the earth will attract electrons from ground.
That is the role of akula/ruslan antenna across the grenade, at a precise timing a strong narrow positive
HV pulse (or train of such pulses) applied across antenna  will attract a bunch of electrons from ground into the grenade circuit.
Then they become trapped into magnetic field of grenade as long as this magnetic field is at its peak and
do their good work inside grenade. That part is still working in progress..
It is the reason Ruslan insisted HV pulses to be applied when current is at its apex in inductor, as then magnetic field is at its apex also.
skywalker66
Hi Void
Hi Jeg,
You say "We know that current doesn't exist with out voltage", but we know pure voltage can exist with out current, do we ? Take for example a battery unconnected to nothing. Jut voltage available there.
Why would not exist also current with out voltage. Take as example a transformer, secondary just a heavy cooper closed ring (ideal superconductor). Isn't there only current in that ring with out voltage?
"Current is always flowing from higher voltage potential to lower."
Current, yes - according convention from conventional science, but electrons will flow always from lower to higher potential (voltage).
skywalker66
A very valid and inspired question. Who put the right questions is on the right track of the truth.
But your question is also backward. Right one would sound like "What if our conventional devices work at higher potential levels than the earth itself?".
It is the case with all kapanadze-akula-ruslan devices. All that stuff - grenade, inductor coils, drivers - all these working in conventional way, nothing unusual there, but they are
enclosed, shielded into positive HV be means of so called "antenna". When that happens electrons start to flow from earth into grenade shielded by positive "antenna" thru ground connection.
Now these new electrons adds to conventional current from grenade.
All it matters is timing and technical details to be worked out.
Jeg
the earth.
Hi Void, Skywalker
In general lines we see the same thing. I attach an image for a better visual understanding. Tanks with water represent the environment, our battery, and load.
Case1 is our conventional tech.  Interaction vanes open when we press the "on" button. Current from battery flows to load but also to the environment as both load and environment are at lower voltage potentials. Losses are unavoidable.
Case2 is the reverse process when our battery and load work at lower voltage potentials than earth itself.
