0 Members and 159 Guests are viewing this topic.
skywalker66
Quote from: Hoppy on March 26, 2016, 06:48:46 AM
I think we have established that it could be a pumping action involved. However, when the HV pulse stops from disconnection of conventional supply, how is the HV re-applied for next cycle? Conventional pumps need a constant power supply. If an amplification effect takes place what in the grenade setup could be doing the amplification?
Yes, a pumping effect if you like this name. HV pulse driver continue to be powered from loop-back power supply of course (if you hit in the amplification thing). It take just a lite power to create these HV electrostatic pulses.
Amplification effect take place  thru addition of electrons. You already have voltage at grenades legs and an limited amount of current thru induction means induced by
inductor (L-C-L resonance). You just adds more electrons (current) available in that conventional transformer thru electrostatic pumping, if don't do that, you have just a very ineffective transformer (inductor /grenade).
Dog-One
In effect, you are tricking nature into a condition it thinks it's no longer at equilibrium when it really is, just for a brief moment, causing a current flow.  At the end of that time interval, you provide an alternate path for things to balance between earth and air; nature finds a new balance that costs you nothing.  In the meantime, the energy you collected in step one has already been used up by the load.  Then you repeat the cycle.
Err, something like that...
skywalker66
Quote from: Dog-One on March 26, 2016, 08:48:55 AM
Yess. just like that. You express it well. Thanks.
In fact you never steal nothing from nature, surrounding space, whatever you get from there is emitted back thru load dissipation into nature. Load is part of nature.
All is part of our universe, you can't add nothing to it, nor get something from it, all that is just limited illusions. But you can initiate processes. In Universe is never energy crisis, and seems it always thrive.
From where our Sun gets his energy, fuel, whatever ? Is there a replenish conduit from some provider ? I think not.
As something off topic, our scientist say a star at the end of its life can collapse into a black hole. But there is a black hole from the beginning. Is its core. It just pass in the next state of evolution.
You may be surprised, but a black hole is a universe in it self. Our Universe is a big black hole. Why do you think is so dark out there in cosmic space? All radiations emitted by everything from atoms to stars and galaxies is absorbed in space, and they are in turn feed by space. Is a never-ending process.
Void
Hi Jeg, the problem I have found is that it is much easier said than done. :)
You can play around with an 'avramenko plug' setup with one side of the capacitor
earth grounded, but in my tests so far that arrangement is not OU, or you can play
around with tesla coil setups, since tesla coils do generate some current on the ground
wire when the bottom of the tesla coil secondary is connected to earth ground, but other
than that I have found that it is very hard to get any significant electrical interaction between a battery
powered device and earth ground in practice.
Something for us to keep in mind is that in 'conventional electrical current' we talk about current flowing
from the more positive voltage terminal to the more negative voltage terminal, but according to physics
electron current really flows from the more negative terminal to the more positive terminal. I guess then
if you want to try to draw in electrons from the earth, you would want to generate a positive
voltage spike with respect to the earth potential, rather than a negative voltage spike as I mentioned
earlier. However, from my own experience this is easier said than done to find a way to make this
work other than using the two methods I mentioned above. This has lead me to think that the earth ground
connection might actually serve a different purpose. As Nick has pointed out, Akula did demonstrate in
an early video that his first self runner would self run with no earth ground connection. The question
as always however is whether that was a valid demonstration or not. :)
NickZ
   Hoppy, Verpies, and all:
  There is a very good explanation of what are the "disruptive discharges", cold electricity, Aether, etz...
   As many of you don't believe what I mentioned previously about the Aether, or that it even exists, perhaps, you'll believe what is explained, here.
   http://www.teslasociety.ch/info/NTV_2011/free.pdf
