0 Members and 224 Guests are viewing this topic.
NickZ
  Jeg:
  I'm also working on the same previously posted Ruslan Kacher driver circuit.
  So far, I can't get it to oscillate for me.  But, I will. I don't use the same 2sc5200 transistor, which may be why it won't oscillate.
  Geo, is using the same Kacher circuit and it looks like he IS able to obtain the amplification effect.
skywalker66
Quote from: NickZ on March 30, 2016, 09:48:05 AM
  Jeg:
Nick,
if you use for you kacher a tv or monitor transistor from horizontal deflection driver as I remember you said previously it most likely won't work (oscillate)
for kacher because of its very low hfe coefficient. Better you get one of this 2SC5200 or MJE15030.
Can you tell more precisely the code marked on your kacer transistor ?
Hoppy
Quote from: NickZ on March 30, 2016, 09:00:16 AM
  I ask for your cooperation. No need to worship anybody.  But, you could try to be more friendly, if you are looking for free hand-outs.
  What goes around,  comes around.  No need to,  to shoot, first, and ask questions later.
OK Nick, I've said my bit and will leave it at that.
GeoFusion
Hi guyz :)
Matt,
haha yeah I know I should wear some sandals or something or be elevated from ground,
I do have a rubber/plastic chair there that would help. I really have no fear for electricity
it's only to keep in mind where dangers are and how it behaves. I might be crazy haha. ;)
But I wanted to show this on bearfoot for the fact that radiant and HF has many characters and
how it reacts with the environment and your own body near it or direct, We should just be careful
with the streamers, they could easily burn a whole in your finger or hand.
Nick,
Yes the push-pull will be operational soon the moment I get my parts.
yeah, now you could see the shorter secondary, but right now what you saw on vid about almost no streamers is
because it was on 12V.  when connecting 24V + it will give the same amount of streaming and connecting
the Antenna increases the lenght and strength of RF arc. I could have recorded a streamer if I remembered. but that
will be in the next video, one 2x car battery ;) to remove doubts in other terrains.
I remember seeing your video, I am curious how you have your wiring connected nick :) could you record this
once more? and maybe with a bit more clarity to see where everything is hooked up. it's to remove thoughts.
you should try it without the switch :), and connect and disconnect the wires which are connected to where they are.
try it.
Jeg,
Thank man :)
Void
Thank you for your extensive reply on the subject :),
Oh yes this video will surely help alot to understand how the system behaves.
oh btw when referring to a positive or a negative on the plates, it's the charges which I am pointing at of different potential :)
I do know it's not the same as how we use the terms of DC , well aware of that. Yes ground wire lenght does make a difference
after all :).
Yes On the componant parts have to be fixed
for sure befor continuing.
on the part with PSU connected to mains and being bearfoot and lighting light between a metal surface and my body with ground
is what I wanted to do, to eliminate fears of ppl where to understand how radiant works, is not the same as
conventional electric mains voltage :) but could be very dangerous still.
HF offcourse is the reason why I was not hurt but still it will make you think why mains did nothing to me,
In the next Video I will show how I reeinact this all by using 2x car battery 24V.
the same results will appear ;). I've done it befor but I think it's necessary to put on recording.
Will also do the same with my rubber isolated chair sitting on it while holding the plate one hand and other hand ground line with bulb
and same results :). I will only show and tell if I my self Have witnessed it and will record if it works.
analog meters for sure, they are coming now in with an entire pakage :) can't wait to continue.
Tomtech
:) saw the link you provided me.
I have many files on that particular setup of ruslan but I do really think it will work if
you only know how to mediate the inputs together for it to synchronize,
Btw the kacher and the secondary to ground will not work, secondary needs to connect to gate.
otherwise need another Tesla Circuit for it.
I will also try that one out sooner or later and make it work.
It's alot simpler then other setups :).
Nelson,
Keep it cool man ;) keep us updated somehow alright.
check PM
CHeerz~
Void
Quote from: Tomtech29 on March 29, 2016, 06:19:11 PM
Hi.
I think that you should also consider the kind of operating system
- confirmation that the work can substantiate most of the structures Ruslan
1 a simple system to power Kacher
2 coil 168T. Grenade
3 voltage of 1000V. capacitors 1uF
4 interrupt nanosecond
5 construction of the transformer from 1000V step down to 12V 3 Amps.?
6 inverter high efficiency
7 the question of whether such low power that we get from the Tesla coil we are able to get convert (against the background of that was enough to Kacher and more) :D
- if the transformer has the current capacity???
P.s anyone thought this construction?
Hi Tomtech. Do you have any ideas on how the MOSFET can be switched with very short duration pulses
in the nanosecond range? I suppose it may be worth a try... :)
