0 Members and 125 Guests are viewing this topic.
NickZ
Quote from: skywalker66 on March 30, 2016, 10:08:53 AM
Nick,
if you use for you kacher a tv or monitor transistor from horizontal deflection driver as I remember you said previously it most likely won't work (oscillate)
for kacher because of its very low hfe coefficient. Better you get one of this 2SC5200 or MJE15030.
Can you tell more precisely the code marked on your kacer transistor ?
  Yes, I use the Tv horizontal deflection transistors for my Kacher. I believe that it was the C5251, which was a 1500v, 15A, or so. Which did work as I've shown in my videos, for the last several months. But, now the code numbers are gone, as they've been worn off. And, I've also tried a few others that also came off of the older CRT monitors, or Tv.
  But, now when making a new Kacher circuit, which includes the caps, and choke, as per the diagram, I shorted out that same transistor while connecting the meter to it.  I will order the recommended 2SC5200 transistors, as well as all the other components needed to rebuild a new non-Mazilli type of push-pull, also. This will take some time for me to do, as usual.
  One of the transistor that I can't get to oscillate is C5520P, as well as several some others.
NickZ
Quote from: verpies on March 30, 2016, 05:09:44 PM
We could come to some kind of consensus if you'd accept that atoms are made out of Aether, too....or everything is made out of Aether.
As long as you think that matter is a different substance, like fish swimming in an aquarium full of Aether, then we will "transmit on different channels".
   I would very much like to reach a consensus. And, yes, everything seen and unseen is created from the presently undetectable Aether.   Ok?
   Call it what you will, dark energy, dark matter, or just Aether.  The main thing is just how to tap this unseen source.
Jeg
Hi guys :)
Void, yes i still use the blue box of Allega's to create the synchronized thin pulse. The problem for me is that my yoke doesn't have more space for winding a 40T secondary so to feed with 130V-150V DC my IRFP460. (Which triggers Tesla coil). In addition i don't want to make a second Push pull as Allega did, in a separate yoke core just for that. So what i am testing right now is feeding my Katcher as i told you with a high voltage (200V) kickback out of my mosfet when i drive it with the synchronized pulse. But, two days now i can't start my katcher to oscillate even with continues 24V supply (as Nick). I will try again today. I use a 2sc5200 (Toshiba).
(If someone has any idea on any improvement please feel free to share it)
AlienGrey
Quote from: Jeg on March 31, 2016, 01:44:07 AM
Hi guys :)
In this circuit the first stage is just an on time for the first FET through the coil _---_--- like this it inverts the signal so it's output is off, unless it's input is triggered correctly it's off when it should be on ?? the other thing is when you look at some devices they use a tv high voltage transformer and spark gap, where does that fit ? and should it be AC Pulsed DC or straight DC ? and the Katcher is the transmitter coil not the tesla coil, it's like flight MH730 where did it go ? my point is it's all surrounded in deception and secrets, what you see ain't what you get.
Re the dark matter thing if you had been out in space and took of your space suit it would smell of BO perhaps but ''static electricity'' smell of arcing electricity  would be far more prominent, space is full of the stuff !
MenofFather
Hi guys :)
