0 Members and 167 Guests are viewing this topic.
verpies
Quote from: MenofFather on March 31, 2016, 04:02:44 AM
He says, that it is better to use a thyristor, then it will be more efficient.
When ON, Thyristors have much higher voltage drop than MOSFETs.
Consequently thyristors convert more electric energy into heat, compared to MOSFETs.
verpies
Quote from: MenofFather on March 31, 2016, 04:28:32 AM
For 1000 volts you can use IGBT transistor. Maybe better than MOSFET and than thyristor.
IGBTs are slower than MOSFETs.
IGBTs have a higher i*v product at slow speeds, though.   ...but MOSFETs are more efficient above 100kHz.
Read this.
T-1000
Quote from: verpies on March 31, 2016, 07:00:13 AM
They have a higher i*v product at slow speeds, though.
About speed in these days, it can go up to megahertz range, see my datasheet link of ST IGBT in my previous post. ;)
The Turn-on delay time + Turn-off delay time is the limit. For STGW40H120DF2 it is 36+161ns which is limiting frequency to 5.07614213MHz.
verpies
Quote from: T-1000 on March 31, 2016, 07:05:25 AM
That's maximum switching speed, not efficiency which Menofather, brought up.
Above 100kHz a MOSFET will be more efficient every time.
An at that frequency the IGBT will spend most of its time switching while the efficiency is horrible compared to a MOSFET which would have switched long time ago and have been idling ON for a significant fraction of the entire cycle.
T-1000
Quote from: verpies on March 31, 2016, 07:13:40 AM
Not going to argue with you and will just do little Tesla coil driving tests instead.
And about MOSFETs, for example, the IRFP460 is worse than this - https://www.fairchildsemi.com/datasheets/IR/IRFP460C.pdf
Turn-On delay time 110 ns
Turn-On Rise Time 150 ns
Turn-Off Delay Time 380 ns
Turn-Off Fall Time 180 ns
