0 Members and 305 Guests are viewing this topic.
apecore
Quote from: Jeg on April 03, 2016, 04:21:37 AM
Hi apecore :)
Welcome to the forum.
This is a project running for a few years now, and most of us that participate we have already make many cycles of experimentation with this. What exactly  you'd like to know? Do you already have any experience on this or you are at the begin? Experience shows that blindly copying Ruslan's device is a waste of time. If you have any theory to experiment with then it worth your time. If you need any circuits for push pull or other stages just ask for it.
Jeg
Thanks Jeg for the response,
I have spend a year now on Tesla's theory etc. and now ready for some action.
My background is electronics and in my freetime i'm spending lots of time on it.
Yes just started with the Ruslans concept (theoretical),..   Wesleys video´s triggerd me to this concept.
No i don t have a theory to experiment yet, i m completly blanc in what kind of issues you all are busy with.
Therefore i would like to build a experiment of my own without starting all over again on the basic Ruslans concept.
So circuits are welcome it would help a lot in catching up and to be of help in this forum.
MenofFather
Quote from: Jeg on April 03, 2016, 04:04:48 AM
Thanks Menof! Do you think that 24V would be enough for supplying my Katcher?
I think, better use higher voltage and longer pulse. But seem, that free energy apears in Ruslan divice and with very low power kacher, only need find needed frenquency maybe.
Void
Quote from: MenofFather on April 03, 2016, 08:19:30 AM
Hi MenofFather. Yes, I think it is good to keep in mind that one of Ruslan's early replications of Akula's
device was using only a simple kacher driver circuit for the tesla coil, and the power supply output was only 12 VDC.
Ruslan only switched to a 24 volt power supply a bit later, if I recall correctly. So, if Ruslan's video demonstrations
were not faked, then we should be able to get a basic version of this setup to self run with just a simple kacher driver
and a 12 volt power supply for looping.
The frequency that the tesla coil resonates at is one possible variable that may be important, but maybe the quality of
the earth ground connection is also very important. However, Ruslan showed his early simple kacher driven setup working in
his living room with just a fairly short ground wire going over to his radiator. The ground wire was not all that thick as well.
I have noticed that GeoFusion's earth ground connection seems to have a fair bit more impact on his circuit than
the earth ground I have been testing with. Maybe there is something special about the earth ground quality at certain locations,
and if you don't happen to be living somewhere in the world where earth ground has this special quality you may
not see much in the way of results. I do get some increase in output when I connect earth ground to my grenade output,
but the effect seems to be smaller than what GeoFusion is getting, for example. I have been testing
with a ground wire going over to a cold water pipe in my washroom. That should be about as good as connecting a ground
wire to a radiator, but maybe because a radiator has more metal mass and heavier pipes running through the building, it
is better. I don't know. :) Then we also had Akula show his first self runner device self-running in his yard with no earth ground
connection to the device at all.  :o  :)  ;D
Void
Quote from: apecore on April 03, 2016, 07:55:59 AM
So circuits are welcome...
Hi apecore. Welcome to the forum. Ruslan basically has been replicating Akula's second self runner
device. I am attaching a schematic of Akula's 'second self running device' which was apparently made
by Akula himself. You should be aware that any schematic posted by Akula may not match exactly what
Akula actually used in his final working device, and the schematic could possibly have some errors in it or
be missing some details. It is probably best if you just ask specific questions about anything you are
unclear about, but if you watch Ruslan's videos, you can get an overview of various things Ruslan has shown.
It seems that almost no matter what circuit configuration Ruslan has tried, he can still it get the configuration
self running. Not so for many other people who have tried. :)
You can find many of Ruslan's videos posted here (look for videos labelled 'Top Ruslan'):
https://www.youtube.com/user/DragonsLord76/videos
P.S. Jeg: Notice that Akula showed using as high as 60V in the attached schematic to pulse the tesla coil
with the timed pulse...
NickZ
  I have three Earth ground lines that all go outside to the yard, two of them go into my water well.
But, the 5 meter ground line that just goes outside of my house to a ground rod does nothing, in comparison to the other two line in my well.
  What I notice is that the better tuned the devices is to resonance, the better the ground lines will work, and the brighter lights are.
If there is no resonance, there is very little gain (or no gain) from the use of the Earth ground. So, it would seams that the ground lines are dependent on resonance, to be effective.
