0 Members and 135 Guests are viewing this topic.
Void
Hi Nick. Yes, a water well should be a near ideal earth ground connection point if you can connect
your ground wire to some metal pipe at the well which goes deep into the ground, as Akula was doing.
Importance of earth ground?
Considering Akula showed that his first self runner did not require an earth ground connection, but earth ground
apparently made it perform better, I think this suggests something... Nelson also showed in his video that his device
can apparently still self run without an external ground connection. Hmmm... :)
Importance of frequency?
Regarding frequency, Nelson showed a device that seems to self run based on what we could see in the video, which
seems to run at a fairly low frequency such as down in the audio frequency range below 20 kHz, based on the
audible whining sound we could hear in the video when the device had a bigger load connected.  Akula has shown
smaller claimed self running devices (his various lantern circuits) that apparently self run at frequencies in the kHz range. Hmmm...
Now, back to the test bench. ;)
Good luck guys...
Bob Smith
Quote from: Jeg on April 03, 2016, 05:29:32 AM
Thank you Bob
If coils are flat then you can adjust the capacity between them by moving them. What about when coils are fixed on the same axis? I think that by connecting a variable cap between them and treating them as capacitor plates can produce the same results. What is your opinion on this?
Jeg,
I don't want to get off on a tangent. Will PM you.
Bob
NickZ
  Perhaps MenofFather can tell me, what he is saying about the device linked below. Some of us have already seen it.
I'm wondering if it does drain the car battery in time, or not? Or the wattage that it draws? Anything, important about it's operation.  In order to be able to run all those things that he's showing in the video.
  This modified Kacher powered device below, if true, is pretty amazing, concerning the amplification effect.
And it's so simple, you'll laugh...
   It would not seam too hard to loop it, with that shown output, as well.
   https://www.youtube.com/watch?v=wd2OFmlTNNc#t=728.076957
   Void: In the Akula schematic you posted, the 28 turns coils 60v output is then rectified, and goes to light a small 40w incandescent 220v bulb, which continues to then feed the Kacher transistor. So, the pulsed input voltage provided for that transistor can be as high as 220v, or higher.  Yet, in the video his sparks off of the ferrite rod were only a few mm, like maybe 2 or 3 mm, so that would indicated that his Kacher's output to be just 2 or 3kV, at the antenna coil.  What are your thoughts about that.
   On a different note, concerning the ground lines and there effects, here is a recent video by Igor Moroz, showing a couple of interesting things.
https://www.youtube.com/watch?v=UaiKa7pxXtg
NickZ
  Itsu:
  I'm very intrigued by the idea that these devices should not operate by inductance. As there are inductance cancelling counter rotating turns all over the grenade's output coil, as well as on the Kacher's output to the antenna. Which would appear to be responsible for some kind of control over the normal inductance that would be observed if these opposite turns weren't included.
  And, also, how can we tell if what we are seeing or measuring, is or is not anything but the normal HV, HF that we all know and love.  This all would possibly have some relation to the mentioned unidirectional "Aether steams", or maybe not.
   Seam to me that T-1000 is up to speed on some of this, as well. Any ideas...
T-1000
Quote from: NickZ on April 03, 2016, 10:25:09 PM
  Itsu:
If you studied diagram I shared a while ago, it tells you there are two loops:
1) Inductive loop for magnetizing grenade coil from push-pull.
2) Capacitive loop for charging up capacitive element of the grenade coil in electrostatic way from the Tesla coil. Also that initiates electrostatic pump to the ground over grenade coil which make additional resonant electrons flow in grenade coil.
Mixing these two together is giving output boost. This how I see effect there. To create high potential electric field it does not cost you, only losses in driving Tesla coil are accounted. So the output boost is for free to exploit. :)
