0 Members and 109 Guests are viewing this topic.
Void
Verpies and TomTech:  Thanks for the explanation of what ecran means.
TomTech, yes, it is very hard to try to replicate a setup if you are missing
various important details.
Forest: Generators are earth grounded for safety reasons.
I can't say for certain why Kapanadze and others with similar setups needed to earth ground their devices,
but my understanding is that earth ground is needed on those devices for them to function well, not
for safety reasons. :)
verpies
Quote from: apecore on April 06, 2016, 05:30:46 AM
For me as a "beginner",... coil windings and resonance frequencies etc. are they also predictable or is it something unknown?
They are predictable.
Mathematical formulas exist, that can calculate the frequency if you have accurate source data.
Jeg
Hi Urfa and other Guys,
For me as a "beginner",... coil windings and resonance frequenties etc. are they also predictable or is it something unknown?
Hi apcore
In general it is almost predictable. In theory, length of wire correspond to a certain wavelength which in turn correspond to a certain frequency. In practice, the capacitance of the cable which mainly is  inter-turn capacitance affect the final frequency to a small or high degree depend on the coil form.
a.king21
Kapanadze grounding:  On the morning of the aquarium2 demo there was a thunderstorm. Kapanadze said it was too dangerous to do the demo.
When the thunderstorm abated he let the team see the device running. The earth was temporarily disconnected and the device still worked.
I asked Kapa on another occasion if his device worked without an earth ground. He said it would need a separate circuit. When I pressed him
further he said it could be replaced by a wire to the negative of a car battery.
If you think about it - operating a device outputting 2 kw at hundreds of vaults is verging on suicide without a ground of some sort.
- Especially if in the event of a short the only path to ground is YOU. ::)
Void
Quote from: a.king21 on April 06, 2016, 08:03:10 AM
Hi a.King21. Thanks for the comment on Kapanadze.
If there is a lightning storm in the area and you have an earth ground wire going to a device,
if there is a very close by lightning strike then you could potentially get a high voltage surge go up through
the earth ground wire into the device, which could potentially damage electronics in the device. This is the same
for any electronic device however, although Kapanadze's devices could be particularly vulnerable to this
sort of thing. A very nearby lightning strike can potentially damage any electronic equipment that is plugged
into the mains or which has an earth ground connection.
In some of Kapanadze's videos (and videos of some others who showed similar types of devices) it was
demonstrated that the earth ground wire has a AC current flowing on it when the device is operating. That
of course wouldn't be the case if the earth ground wire was just there for safety reasons. This being
the case, it would appear unlikely to me that the earth ground wire on Kapanadze's device is just there for
safety reasons.
Some of us have demonstrated that you can light a light bulb, which is powered from a battery powered
tesla coil setup, with one connection side of the light bulb only connected through a wire to earth ground, or even with
one connection side only connected to even a fairly short wire. However, I have found that even though a light bulb
can still light even if the end of the wire is not connected to earth ground, the light bulb will still light more brightly
when the end of the wire is connected to a good earth ground point. So, as best as I can tell from my own experiments,
the earth ground may not be essential, but performance is improved in that type of arrangement with a decent earth ground connection.
I can't say for certain that this is the reason that Kapanadze type devices are typically earth grounded, and why a current can be
measured on the earth ground wire, but that could be at least part of the reason why the earth ground is needed/used.
I have tried the negative on a garden tractor type battery as a 'ground' in these types of tests, but it did not make
any more difference in my tests than connecting to any larger piece of metal. With Kapanadze's devices, it is certainly possible that there
could be different reasons that he uses earth ground than what I was experimenting with however. :)
