0 Members and 469 Guests are viewing this topic.
Void
Quote from: URFA on April 06, 2016, 06:08:37 PM
In my mini setup(what I shared video)
Input: 12V (1.8--2A)
Load: 220V 40W (brightness %70 around)
In my large size(kacher and other coil etc.) setup
Input :12V (1.2-2A)
Load: 220V 40W (brightness %100 or higher  :D
In my setup I use this scheme
Hi Urfa. Thanks for the info. It seems to be working pretty well.
It is very hard to judge the brightness of a light bulb by just trying to estimate its brightness with your eyes.
Do you have an oscilloscope which you can use to view and measure the waveform across the 40W light bulb?
If so, it would be nice to see a screen shot of the scope waveform across the light bulb, and to know the peak voltage
of the waveform across the light bulb, but watch out if you don't have a x100 scope probe or higher, as there might be
high voltage peaks across the light bulb that could blow a x10 scope probe or even damage the scope. :)
AlienGrey
Input :12V (1.2-2A)
I'm none the wiser, but thanks, Void says he has photographic memory and knows the database like the back of his hand ! Yeah!
Anyway the thing under the cup, do you think it could be a bridge rect 'high speed' ?
Zeitmaschine
Looks almost like that one, posted on March 26.
I really love strange coincidences. ;D
Now would you mind making it a self-runner?
BTW: Interesting comment on that video at 2:54:
»Насторожило то, что  работает  ассинхронное точило с явно 50гц звуком . Как создается 50гц в такой простой на вид схеме ?«
In English: When the sharpener starts it sounds clearly like 50Hz. How can such a simple circuit generate 50Hz? ???
That grinding machine works with a asynchronous motor.
Void
Quote from: AlienGrey on April 06, 2016, 06:58:56 PM
... Void says he has photographic memory and knows the database like the back of his hand ! Yeah!
Say what mate? I haven't said anything like that... My memory is not so good actually... ;D
Dog-One
Input :12V (1.2-2A)
If you happen to have a 12 volt out, Universal Input power supply, I'd sure be curious to know if it can sustain looped operation.
I'll be winding some long secondaries shortly.  Did you go just past the mid-point when you changed direction?  Your schema and coil picture looks like about 2/3rds split.
