0 Members and 106 Guests are viewing this topic.
AlienGrey
As far as I know the wavelength is 'distance' LC is timing, look at his electric fire it's only 'well' lit half way across the bar, showing the waves useful part of the waveform power peaks pos and neg as if pulsed DC or demodulated HF.
Hoppy
Quote from: Zeitmaschine on April 06, 2016, 07:05:46 PM
BTW: Interesting comment on that video at 2:54:
»Насторожило то, что  работает  ассинхронное точило с явно 50гц звуком . Как создается 50гц в такой простой на вид схеме ?«
In English: When the sharpener starts it sounds clearly like 50Hz. How can such a simple circuit generate 50Hz? ???
That grinding machine works with a asynchronous motor.
Yes and it almost certainly is running at 50Hz, so what does this tell us about the device?
verpies
Quote from: Jeg on April 07, 2016, 01:36:01 AM
MegaOhm resistor??? Do you mean connecting my fg in parallel with tank's cap but with the high value resistance in between them?
Yes
What happens on here? Both tank's capacitor and the output capacity of the f.g. are utilized as a series cap???
The high value resistor separates the FG from the parallel LC tank allowing the two to freely oscillate at different frequencies and minimizing the influence of stray capacitance on the tank.
apecore
Quote from: Hoppy on April 07, 2016, 03:49:25 AM
That it generates 50Hz?
Could this been done by the missing part?
The white "unknown" part?  Could it provide a carrier wave?
