0 Members and 142 Guests are viewing this topic.
Hoppy
Quote from: AlienGrey on April 08, 2016, 08:48:33 PM
Thanks for your help but i have found it This guy explains a lot !
https://www.youtube.com/watch?v=QAoo7u1KVSU&nohtml5=False
https://www.youtube.com/watch?v=aChi9WjR71s
https://www.youtube.com/watch?v=Udx4TFr1ics
https://www.youtube.com/watch?v=wp0bAMK_7OI
Cheers for your help
Hi Alien,
Have you worked out the number of turns and wire guage for each of the coils L1 to L5? I found it quite confusing looking at the videos.
AlienGrey
Quote from: NickZ on April 08, 2016, 08:06:24 PM
    AlienGrey:
   There is no feed back circuit on that video. Just the Tesla coil driver, the two big Tesla coils, which are providing the power to light the 100w bulb. At least, not that I've noticed.  But, check it out for yourself, the guy speaks English. It's not a self runner, in any case.
   Verpies:
   "Can there be motion without matter"?
    If I understand the question.
                 My answer is:  I believe in multi-dimentional reality. And that non physical reality is the source of all physical worlds.
   The material worlds and their movements, is only a small fraction of total picture.
   These other worlds unseen by us, some call them Etheric dimensions or worlds, aren't material, like this one is. They are moving. But, invisible to us.
   The above, is only to point out my understanding of where the ever present Aether come from, from these Etheric non physical dimentions.
  One could call the Aether units,  Aether particles, although they are not a material particle. More similar to light, so not to get too confusing.
   I don't know if that was you were asking about, somehow I doubt it. But, that is my reply.
can you have motion without matter, why dont you ask the Obama, Bush administration that one I could say more but won't
Void
Quote from: Dog-One on April 08, 2016, 11:01:42 PM
Without George's system looped, I'm not convinced it is over unity, but he does
make an interesting observation or two...
The Roma Grits device sure appears to be taking George's
concept to the next level with similar simplicity.
Hi D1. Agreed. George did not seem to show any attempt to do any proper power measurements on the light bulb
in any of his videos. He did show what looked like comparing an input voltage waveform taken somewhere
on the input to an output voltage waveform taken somewhere on the output coil, but of course comparing voltage
waveform amplitudes doesn't indicate power. As best as I could tell, George seems to be mainly looking at light bulb brightness
and concluding it is over unity based on that. It might be over unity, but, as we all are aware here, just trying to guess at the
output power based on light bulb brightness is not very reliable. For one thing, I have noticed that bulbs can sometimes
appear bright to the eye when pulsed in certain ways with higher voltage than the bulb's nominal voltage, but the average
power to the bulb may not be as high as one might guess by just looking at the bulb. George is at least showing
a way to deliver good output to the load, so that is good even if there is still a question mark about whether it
is actually OU or not. Urfa seems to have tried a similar sort of LC resonance loop and got good output to his
load as well.
The two approaches George shows in his videos seem to be variations of things we have seen other people trying
such as using an LC resonance to increase current and also the method of timed pulsing as well. One more case to add
to the list of devices that use these sort of approaches to boost the output. I agree that unless George shows looping
the output to make it self run or at least shows powering large loads with a much smaller input power it is still in question about
it being OU.
verpies
Quote from: skywalker66 on April 08, 2016, 02:44:35 PM
Hi Verpies !
I come across some time ago on a document project on internet about negative inductance and possibility use for producing energy amplification.
In that document states about a canceling inductor near 0uH immersed into a HV negative E field wile current passing thru it will act as negative inductance
and can be used into a resonant tank where oscillations amplitude instead dampen will rise. I find this quite intriguing.
If you will and have some spare time to take a look on it, I will appreciate some insights about possibilities described there.
It make sense from an scientific stand point ? I tend to agree with scientific logic used in that document, but my knowledge in theoretical physics have become some rusty lately.
I ask for this because akula/ruslan devices appear to make use of sort of canceling magnetic fields subjected to a HV E field.
I agree with the motional relativity of magnetic and electric fields. I do not think that the majority of electric current is carried by charged electrons.
I noticed that the article does not account for the relative motion with respect to the positive charges on the inner cylinder of the core ...it only accounts for the relative motion with respect to the negatively charged outer cylinder.  Why the unequal treatment?
On the practical side I am surprised by the high length to diameter ratio of the coil described in this article.
Also, I's like to notice that the insulation of an enameled cooper wire cannot withstand 30kV.  I am unclear whether this electric potential difference occurs between the outer cylinder and the coil.
I think there were some experiments done on this forum with a similar device called "Captret" or "Capcoil" but there were significant differences in their configuration.
P.S.
The member Grumage might be uniquely positioned to do this experiment because he has a HV electrostatic machine, a lathe for quickly winding the 1.2m coil, good mechanical skills and a scope.  The only thing he might not have is wire of appropriate size, so you might want to order it for him.
Void
Quote from: Hoppy on April 09, 2016, 06:19:25 AM
Hi Hoppy. I have gathered the following so far from George's videos and some of his youtube comments.
I didn't get any details on 'L4' yet however.
Tesla Coil:
Primary (L1):
Turns: 4 or 5 turns
Wire Gauge: 2mm or 3mm
Tube Diameter: 10 cm
Secondary (L2):
Length: 150m
Wire Gauge: 0.30mm
Tube Diameter: 9 cm
Receiver Coil (L3):
(approx. 1/4 length of the tesla secondary)
length: 38m
Wire Gauge: 2mm
Wind with multiple wire taps
L4
L5
10 turns
George mentioned a tesla coil frequency of 2 MHz and an output frequency of 30MHz, but that
seems to be questionable to me. The tesla coil secondary length was mentioned as 150m, so
I have doubts that the kacher would be driving such a long coil at 2 MHz, especially when  it is all connected in
the way George is doing it. Maybe the way George has some things connected in and oriented it is making
it operate at 2 MHz, but I have doubts about that. I would think that the operating frequency would
more likely be below 1 MHz at that secondary length, but maybe if you play with the primary winding you
can get the kacher to operate at higher frequencies than it might normally run at. The 30 MHz at the output
also sounds questionable to me as well. George showed using a frequency counter in one of his videos, so if
he was relying on that for frequency measurements, it could be off. Maybe with the different things George is
doing in his circuit it is creating some high frequency harmonics, but I would guess that the main waveform
at the output would not be such a high frequency, but who knows. If George was relying on his frequency
counter if his scope if not very high bandwidth, then that might have possibly mislead him there.
P.S. L4 looks like maybe 10 to 15 turns from taking a quick look at the video...
I could be off on that as I just took a quick look. :)
