0 Members and 166 Guests are viewing this topic.
verpies
Quote from: NickZ on April 08, 2016, 08:06:24 PM
I believe in multi-dimentional reality and that non physical reality is the source of all physical worlds.
Did you mean to write?:
"...that, non-material reality is the source of all physical worlds."
The material worlds and their movements, is only a small fraction of total picture.
OK, but non-material does not mean ephemeral nor unmeasurable nor indescribable.
One could call the Aether units,  Aether particles, although they are not a material particle. More similar to light, so not to get too confusing.
I understand that you propose Aether coming in discrete chunks.
So what is the difference between Aether particles and photons?
How does Aether interact with light and other non-material particles?
How can Aether be morphed into matter? ...or do you propose that matter is composed of different substance than Aether ?
How do you propose to measure Aether's magnitude and direction?  Is it a zero-dimensional or one-dimensional magnitude or more?  How many more and why more?
I don't know if that was you were asking about, somehow I doubt it. But, that is my reply.
Not really. My question referred to the possibility of motion without an object.
I did not receive a direct answer about it, yet.
I only got the vague impression of you thinking that every object must be material and non-material particles, such as photons, are not objects.
verpies
Quote from: AlienGrey on April 09, 2016, 07:29:48 AM
Can you have motion without matter?, why don't you ask the Obama, Bush administration, that one I could say more about but I won't
Why won't you?
verpies
Quote from: Void on April 09, 2016, 07:34:01 AM
...as we all are aware here, just trying to guess at the output power based on light bulb brightness is not very reliable. For one thing, I have noticed that bulbs can sometimes appear bright to the eye when pulsed in certain ways with higher voltage than the bulb's nominal voltage, but the average power to the bulb may not be as high as one might guess by just looking at the bulb.
Amen.
A closed box with the bulb inside and a PV cell connected to a milliammeter is much less to deceive than the eye.
Grum appropriately calls it the "Wattbox".
Hoppy
@ Void,
Thanks for your take on the coil details for George's device. I also counted 10 to 15 turns for L4 by eye. Although as we know, the lamp brightness cannot be used as a reliable estimate of power consumption, the marked increase in the brightness of the 60W bulb when all feedback coils were fitted, running on supply of 24V / 1.5A, does suggest that this setup might be worth experimenting with.
Dog-One
Quote from: verpies on April 09, 2016, 08:48:24 AM
Here's one I have yet to see a satisfactory answer to...
Some physicists contend an electron has to rotate 720 degrees to make one complete revolution in real space.  I would like to know how they apply a marker to some point on the surface of the electron in order to track the exact angular displacement.  I don't particularly disagree with their claim, because it would make sense based on the Dirac equations that an electron does indeed oscillate in a figure-8 pattern into imaginary space then back out into real space.  I'd just like to know how they physically confirm this to be true.  As far as I know, the only way to measure imaginary space is mathematically, so how could this be positively confirmed?
My answer is spin or rotation about an origin.  I see no reason spin would need to be confined to a particle of matter, though it does make a good candidate.  Spin could just as easily be attributed to a force or to a field which may create a force.
As far as matter is concerned, I would highly suspect this to be some sort of condensate of energy, wrapped upon itself, giving the form we know as matter.  Typically when I think of energy, I envision something on the move, displacing with time.  If energy is able to wrap itself up, it may still be moving (spin), but is no longer moving as a vector, revealing itself to us as something else, that something we define to be matter.
