0 Members and 135 Guests are viewing this topic.
verpies
Quote from: NickZ on April 09, 2016, 12:17:40 PM
Verpies:   The Aether can't be measured by using our current technologies. Yet, it's physical effects can be observed,
Yes, it can but it is true that when the primordial motion becomes looped in space, then the motion becomes hidden and we start calling it by different names such as "spin".
So, in a way what you call "Aether" is hiding in the plain sight.
verpies
Quote from: skywalker66 on April 09, 2016, 02:42:40 PM
But there is something also which puzzles me , assuming coil develops some sort of negative inductance due the influence of negative cylinder as the document states, and have magnetic field, wouldn't that field be dissipated by the cylinder itself as a heavy secondary like short-circuit turn  ?
Yes, that's why I would cut a slot in the cylinders
Zeitmaschine
Quote from: x_name41 on April 10, 2016, 04:41:41 PM
and that component marked as "cap" that's not really the capacitor, this is actually a 50 hertz a shaper (pulse former like 50Hz Triac AC Power regulator).
Any idea what the schematic of a high frequency to 50Hz converter (pulse former) could look like, especially when it is connected with two wires only?
x_name41
Quote from: Zeitmaschine on April 10, 2016, 07:30:50 PM
this was actually a suggestion
Quotebut actually if kacher is modulated with 50 hertz at the input, then the output should LC filter  :)
AlienGrey
Watch this https://www.youtube.com/watch?v=NwMos1y1Peo&nohtml5=False
Rip this apart at your own risk ! builder be wary.
But note in this database only find it, an existing PDF file exists, the same warning applies.
Note Ne magnets apparently need integrating iron alloy rotating spindle section.
