0 Members and 715 Guests are viewing this topic.
T-1000
Quote from: lost_bro on April 13, 2016, 01:17:48 PM
Sounds like were re-inventing AM, ie; double side band full carrier wave.
Close enough, just in this particular scenario the high frequency wave is inside of low frequency wave. This bit is opposite to classic AM.
Also Ruslan in https://yadi.sk/i/KOHwNZ2HqmQuY and https://yadi.sk/i/Yh9qen8nqmQua was pointing out the effect happen only when those waveforms appear on grenade coil (source link: http://realstrannik.com/forum/freeenergylt-antanas/708-povtorenie-ustanovki-free-energi-kolobukhova?start=684#47944 )
Cheers!
Zeitmaschine
Quote from: lost_bro on April 13, 2016, 12:57:03 PM
It is interesting as R. Hull and his group from Virginia were (along with the Corum brothers)  some of the original pioneers of the renaissance of Tesla's 3-coil system (they actually built the monsters). The 3-coil system is the Actual real-deal Tesla coil that was developed and run at Colorado Springs in 1899. Not to side track the thread anymore......
Just as a coincidence: A 3-phase transformer can also be considered as a 3-coil system. And just as another coincidence: The Stepanov OU device works with a 3-phase transformer.
So the question goes: Could it be that a 3-phase transformer can work somehow like Tesla's 3-coil system if one connects it accidentally the wrong way with respect to its normal mode of operation?
Void
Quote from: T-1000 on April 13, 2016, 02:04:11 PM
Like this?
T-1000
Quote from: Void on April 13, 2016, 05:49:14 PM
Like this?
Youp, also it is same like I had in Yoke experiment.
The main difference between AM signal is, there are 2 inputs with low frequency and high frequency signals for making similar wave.
nelsonrochaa
"Owing to this feature I expect that this method of raising the e.m.f. with an open coil will be recognized later as a material and beautiful advance in the art. No such pressures — even in the remotest degree, can be obtained with resonating circuits otherwise constituted with two terminals forming a closed path. It is also a fact that the highest pressure, at a free terminal, is obtained in that form of such apparatus in which one of the terminals is connected to the ground. But such "extra coils" with one terminal free may also be used with ordinary transformers and by using one such coil on each of the terminals of the transformer, practically any spark length may be reached"
"As has been stated on a previous occasion in connection with this subject, to enable a considerable rise of pressure to take place in a circuit, the same must be tolerably free from inductive influences of other circuits. It follows from this that, although with a secondary in loose connection with a primary a very high pressure is obtainable, yet the pressure will never be as high as when an "extra coil" not in inductive connection with the primary is employed to raise the pressure, because the secondary always reacts upon the primary thus dampening the vibration, while the "extra coil" does not react in such a manner, the rise of pressure being simply due to the factor pL/R."
"Obviously the maximum rise will take place when the period of the excited system or "extra coil" is the same as that of the oscillating system impressing the movement, for although the results obtained with a lower or upper harmonic, and particularly the former, may be sometimes so remarkable, as to be mistaken for effects of the true vibration, they are nevertheless always inferior, and I as a rule try the first upper and undertones to be sure of the result, when there exists any doubt in this respect In ordinary practice the first element which is given will be the frequency, hence the wave length must be assumed as the first fixed quantity."~
