0 Members and 716 Guests are viewing this topic.
lost_bro
Quote from: T-1000 on April 13, 2016, 05:57:21 PM
Youp, also it is same like I had in Yoke experiment.
The main difference between AM signal is, there are 2 inputs with low frequency and high frequency signals for making similar wave.
Interestingly enough, or just by co-incidence my LTspice sim. of the D.S. table top device will also give this modulated carrier-waveform........
take care, peace
lost_bro
lost_bro
Quote from: nelsonrochaa on April 13, 2016, 06:06:19 PM
"Owing to this feature I expect that this method of raising the e.m.f. with an open coil will be recognized later as a material and beautiful advance in the art. No such pressures — even in the remotest degree, can be obtained with resonating circuits otherwise constituted with two terminals forming a closed path. It is also a fact that the highest pressure, at a free terminal, is obtained in that form of such apparatus in which one of the terminals is connected to the ground. But such "extra coils" with one terminal free may also be used with ordinary transformers and by using one such coil on each of the terminals of the transformer, practically any spark length may be reached"
"As has been stated on a previous occasion in connection with this subject, to enable a considerable rise of pressure to take place in a circuit, the same must be tolerably free from inductive influences of other circuits. It follows from this that, although with a secondary in loose connection with a primary a very high pressure is obtainable, yet the pressure will never be as high as when an "extra coil" not in inductive connection with the primary is employed to raise the pressure, because the secondary always reacts upon the primary thus dampening the vibration, while the "extra coil" does not react in such a manner, the rise of pressure being simply due to the factor pL/R."
"Obviously the maximum rise will take place when the period of the excited system or "extra coil" is the same as that of the oscillating system impressing the movement, for although the results obtained with a lower or upper harmonic, and particularly the former, may be sometimes so remarkable, as to be mistaken for effects of the true vibration, they are nevertheless always inferior, and I as a rule try the first upper and undertones to be sure of the result, when there exists any doubt in this respect In ordinary practice the first element which is given will be the frequency, hence the wave length must be assumed as the first fixed quantity."~
See attached drawing to accompany the above:
Iron core XFRMR used in Resonant rise configuration from the same, C.S.N.
take care, peace
lost_bro
Void
@Nelson: Thanks for those quotes.
The guy in this video seems to be using an extra coil to get high voltage out
with low input power. You can see the extra coil hanging down towards the floor from the
end of the tesla coil.
http://www.youtube.com/watch?v=pP5FiCbLu5M
@Lost_bro: That's interesting. Re the Don Smith cct sim, what pulse width is being applied to the primary winding?
P.S. IS that R. Hull PDF downloadable from somewhere?
Dog-One
Quote from: Void on April 13, 2016, 06:27:06 PM
"... the same must be tolerably free from inductive influences of other circuits."
Putting the extra coil at a 90 angle from the secondary would indeed make it "tolerably free from inductive influences".
Good stuff guys.  Keep it coming...
M@
lost_bro
Good evening Void
The pulse width is 60ns measured @ 50% amplitude.  It's a W.I.P. and the LTspice sim.s are just a small part of it as I am designing/building a replication of the system (Salty Citrus Chinese replication https://www.youtube.com/watch?v=cni08WjLTcc), been at it for almost two years now..... If you are interested, check out my post @ http://www.overunityresearch.com/index.php?topic=2.msg54390#msg54390 on this subject.
Hull's book has been out of print for almost 10 years now, P.M. me and I will email you a copy.
take care, peace
lost_bro
