0 Members and 70 Guests are viewing this topic.
NickZ
     Akula 0083 may be correct, there may even be less than 5 guys in the whole world that will take a shot at it.  It doesn't matter, as ultimately we'll be able to buy it,  soon enough.
  The Chinese may even beat the Russians, in this race, or soon afterwards and sell it at 1/2 the price,
free delivery. Just watch!
   But, I don't care, as I NEED IT NOW!
   Maybe some people will not need it, at all.  Maybe.
   Just pay your electric, gasoline, and gas bills,  keep paying... keep burning things up, the sky is the limit.
T-1000
Quote from: verpies on May 15, 2013, 01:33:52 AM
In my opinion it is a shot in the dark to try to replicate such devices without:
1) Scope shots of current and voltage at all significant points.
2) Complete electronic schematic diagram
3) Part & material specifications (especially ferrites)
4) Exact physical dimensions
5) Spectrograms / Smith charts of all reactive components.
Last point is the least important. I would gladly resign from having a video if I had pt.1.
Only Wesley and his team provided pt.1 for the Yoke device.  That was exceptional by itself.
Even ZeroFossilFuel replicated effect in http://alt-nrg.org/Kapanadze.html I do not know anyone else who got it and shown in Internet except tiger2007.
The FE topic involves long series of experiments with things I tried to describe as starting point and that means you need to be commited to find it out. Obviously there is no 1:1 replication possible from various authors and your circuit version is best bet on this... The main problem with replicating same circuit is, even authors cannot make 1:1 copy because the tuning is involved in in each individual circuit with different frequencies and stuff.
MenofFather
Dally use two frenquences seems, I guest, is 1 kiloherc sinus 100 about volts and 1-0,2 Gigaherc 1000 V impulses, this maybe is a key. Need sinus and impulses and ground or conected to primary wire one and secondory wire. Can use 50 herc sinus and pulses. In Akula divice other principe, hard to explain, and we do not known all his construction, so I not say about his divice. Stev mark also, remember, say, that is otput is DC pulses and about mixing many frenquences. And looks his say, that then you puch three let say notes in pianino let say, then saund in right combination of notes let say be lauded, whan saunds of this notes saunds separettely. So maybe need three or maybe minimum two frenquences and in right its frenquency its make more energy, than you put in.
T-1000
@MenofFather
http://www.bibliotecapleyades.net/tesla/esp_tesla_20.htm
"From theses experiences it became apparent that the fire balls resulted from the interaction of two frequencies, a stray higher frequency wave imposed on the lower frequency free oscillation of the main circuit.
As the free oscillation of the circuit builds up from the zero point to the quarter wave length node it passes through various rates of change. In a current of shorter wavelength the rates of change will be steeper. When the two currents react on each other the resultant complex will contain a wave in which there is an extremely steep rate of change, and for the briefest instant currents may move at a tremendous rate, at the rate of millions of horsepower.
This condition acts as a trigger which may cause the total energy of the powerful longer wave to be discharged in an infinitesimally small interval of time and at a proportionately tremendously great rate of energy movement which cannot confine itself to the metal circuit and is released into surrounding space with inconceivable violence.
It is but a step, from learning how a high frequency current can explosively discharge a lower frequency current, to using the principle to design a system in which these explosions can be produced by intent.
And this is part of solution in FE generators. The another part is actually applying this into two magnetic fields making induction from resulting magnetic field vectors...
verpies
Quote from: T-1000 on May 15, 2013, 05:15:34 AM
Obviously a 1:1 replication is not possible, that's why we need these I&V scopeshots and spectrograms to know what to aim for and what to tune for.
With those scopeshots we can use different yet equivalent circuits (and often better ones) to achieve the same waveforms and with less financial investments (using parts on hand).
Without this info it's just a shot in the dark and it is not surprising that so few good engineers want to experiment blindly. Randomly applying magnetic fields, frequencies to various coils, capacitors and cores creates so many possibilities, that it's easier to win a Lottery than build one of those devices without scopeshots.
The Tesla quote above, does not significantly decrease the number of these possibilities.
