0 Members and 772 Guests are viewing this topic.
Void
Quote from: ronotte on April 14, 2016, 06:20:42 AM
Hi all,
it may be interesting to know that long time ago' after suggestion by STAAR group (Wesley, etc) I succeeded in obtaining an almost perfect H.V. Trumpet waveform!   The resonant rise is perfectly observable and the amplitude significative. The circuit used, very simple, included a Kacher driving a set of 3 pancake coils....respectively a primary with tick wire and a secondary split on two mirrored pancackes. Circuit tuning quite difficult...
The posted pic is tagged with interesting notations.
Note: NO OU observed from  recovered DC voltage on resistive load....but capacitor step charging and its rate is evident!
Ciao
Roberto
Hi Roberto. Yes, I think the trumpet waveform can occur due to the resistance of a sparkgap, for example.
As I mentioned in my previous post, the scope waveform showed as distorted because I was just holding
the scope probe in the air near the coil. From previous tests I have done, I think it is actually fairly close to a typical
trumpet waveform. From my own point of view I don't think a trumpet waveform in this sort of setup is an indicator
of 'negative resistance', but is actually an indicator of resistance causing the coil to charge with a time constant curve.
Jeg
Quote from: verpies on April 13, 2016, 10:31:08 AM
Regardless whether they are coupled electrically or magnetically, their frequency response will depend on the amount of coupling.  Read this for more on this subject.
Exactly what i was searching for. Thanks ;)
Hoppy
Quote from: Zeitmaschine on April 14, 2016, 06:20:25 AM
How can you know for sure that Kapanadze did not hoax you?
If one asks Kapanadze a lot of nagging questions about his device then it could easily happen that he makes something up in order not to disclose anything real.
What about Stepanov and his 3-phase transformer? Where can I find bifilar windings and precisely measured wires here?
And generally: Who says that we need a classic Tesla-style coil in order to get OU? I can't see such a coil in the 2004 video, just something like a cable extension reel.
But anyway: Why would a classic Tesla coil need that odd switching method?
From Wesley's account of his meeting with Kapanadze, I don't see how we should be confident that what he says about his device is true.
The odd switching method is in my opinion most likely what you suggested - a bad connection. He seems to prefer just twisting wires together, rather than properly connecting them.
Hoppy
@ a.king21
"It's sad seeing people re-inventing the wheel. So please bookmark this post."
What wheel are you referring to?
Hoppy
@ a.king21
"6 This one is for you Hoppy.  All Kapanadze has to do is use a Kacher in the following circuit
and all he would need to receive the transmitted power would be an EARTH GROUND and
a reverse winding as per the Tesla spec.... and so would Akula, Ruslan and any other purveyor of "FREE ENERGY".
THE END.."
What makes you think this?
