0 Members and 575 Guests are viewing this topic.
Zeitmaschine
Quote from: Hoppy on April 14, 2016, 01:58:18 PM
That sounds more like a sticking latching relay or a faulty switch in the relay holding loop.  ;)
A sticking latching resonance would be something more advanced - especially since there is nothing that could need a relay to be switched.
Would be embarrassing if TK pulls the inverter plug and the lamps continue shining bright because of a sticky relay, wouldn't it?
T-1000
Quote from: verpies on April 14, 2016, 02:04:46 PM
Note that Russians speakers wrongly write "LF carries HF" instead of "HF rides on LF".
This is a grievous mistake in English language because the former expression is reserved for AM modulation that involves multiplication of two frequencies (the HF carrier and a LF signal) and the latter expression denotes waveform addition (which is what is visible on the first oscillogram below belonging to the famous Yoke device).
As you mentioned my old scope shot.. :)
The 2 signals was mixed up by induction there and not on just by electronics where one signal drives another. The scope shot can look same but what is happening behind it can be very different.
Cheers!
NickZ
  TK used the spark gap on the first device, which may be the only thing needed for it to do what later devices did by electrical switching.  Nor have his later devices able to improve on the output of his original device. Other than the 100kW unit.
Which again, was probably NOT built by Kapanadze, nor has it been further developed, by a newer design.
   I agree with Void on the wireless transfer of energy, is not the same mode of operation as what these table top models use.
   Especially the ones that don't need a ground line, at all. As they are not taking in anything from the ground. Yet can produce the shown output.  Again,  if true.
Grumage
Quote from: NickZ on April 14, 2016, 01:26:55 PM
    a.king21:
   Did Kapanadze also say that he had personally built all the devices that he has shown?
As I doubt it, nor that he even has the ability to do so. As he is not even familiar with Tesla's ideas, but someone else may be.
   IF he did not build those devices, then you were asking the wrong guy for advice.
   And why did you not get a device to take home with you?  For your $10.000 investment?  Such as the Aquarium device?
   Sounds to me like TK was only a poor sales representative, for the real but still unknown builder(s) of those various projects.
   We observe now that an Earth ground is NOT absolutely needed, to produce kWs of power.  If true.
   Nor is our idea related to the transfer of energy through the ground. As individual and portable self runners are what we are working on.
   Nelson's shown device is a low power example, as well as some others that we've seen, needing no ground line, to confuse the issue.
   The reason that we are all still looking for alternatives on the internet, is because NO ONE can build a Kapanadze replication, as there is not enough information on it. As he's made a point of hidding the secret of it's mode of operation.
Dear Nick.
"   Nelson's shown device is a low power example, as well as some others that we've seen, needing no ground line, to confuse the issue.  "
What do you think the scissors on the draining board are doing ? That Stainless Steel drainer is securely bonded to earth, it's a regulation.
Cheers Grum.
Void
Quote from: Grumage on April 14, 2016, 02:36:17 PM
Dear Nick.
Cheers Grum.
Hi Grum. I believe Nelson showed in that same video that his device would keep running even when not using
that ground connection with the scissors. I think Nelson stated that it had less power without the ground
connection however.
