0 Members and 97 Guests are viewing this topic.
Grumage
Quote from: nelsonrochaa on April 14, 2016, 03:46:13 PM
Void ,
myself many times have some difficulties to linking and apply in practical my ideias;)  Is normal in research Work  because some of this informations are most of time "underlines" .
The most important sometimes is try to not let hour brain polluted because are so many information and different opinions about  this type of subjects .
about the post of Grumage with my old video is really a scissors  make contact with ground but in end of video in last minutes i show without ground , but that prototype are to old (8 months) but i  have that box yet in my home in Portugal, like other smaller basic circuits that i make  to record myself  that great things are made with first small results. :).
I think the important at present is understand how to replicate the extra coil circuit first and to that Last Bro start sharing a good information .
If we have a big problem , better don't try to solve that in one shot ; better divide the big problem in small parts and it will more easy the journey  until end :)
good luck
Void
Hi Nelson. Yes, I try to break things down to simple pieces in my testing.
I will look more at the idea of the extra coil resonating freely.  Thanks again for the comments.
AlienGrey
Nelson as far as I know IONs are charged particles that are unaffected, and waste no time with magnetic fields
Moray talks about his Swedish rock I think e mentioned it contains radium another mineral, he does list it's makeup on Everything @ rexresearch.com, under Moray, it makes interesting reading.
He also believes the energy from radiation from our star and others in the known galaxy, other than that he gives no other details.
Of course I could be giing the completely the wrong interpretation I'm giving you here ! ;)
NickZ
  Nelson:
  Thanks for your comment, concerning the ground line, and it's uses.
  However, we have been working on the Ruslan/Akula replications, which uses the antenna as the " third, or extra coil". This antenna coil, has yielded no significant additional output, for most of us, as yet.  Perhaps Geo will be the first to show how it can work as was planned to provide for a self runner.  At least, I hope so.
    I have been working for years on simpler circuits,  to try to turn them into self runners.  Such as Joule Ringers, Joule Thiefs, Cross-Over circuits, Dr. Stiffler Exciters, Kacher circuits, as well as several others.
  How much simpler can it get? Yet, none of them produced more out than in, or are able to self run.
  I for one would like to find a project that works. And not to continue to waste time on what doesn't.
  So, we need much more than just hints, to find our way. We need a hand...  like yours.
nelsonrochaa
Quote from: AlienGrey on April 14, 2016, 04:19:17 PM
Hi AlienGrey
answer to your question :
Yes ions are charged particles with not interact with magnetic fields normally but with electrostatic fields  ,  and we have some substances in ground and air that when stimulated with  negative electrostatic charges are able to liberate alfa particles ;) because change their state .  Alfa particles ionize very easy and create a current even can throw by glass . This way you cite the subject of Thomas Moray and about the spark gap.'from a spark I can make a forest fire'  I my self would like to see someone prove it !"
  But not a convencional spark gap. :) like he said " is not electrons process but ionic process " but without know how to active that process .....
And yes you are right this type of radiations are generated everyday even us could see it . If you think a more bit you will see way Tesla in their radiant patent not show only one type of radiation used to test their radiant circuit, but it talk about the "invisible particles" alpha ray , gamma and so on  . That particles react in a particularly way with metals .
But way you want to go by this path if you not able in this moment understand the basic to make this interaction ? Maybe will be more easy start by the floor not by the roof :)
About the rock that Moray used  (quartz with lines of radium ) can emit alpha particles in a particular condition but after we discover that could be created from bismuth too and so on we call cold fusion .
If you think very well my words will made some Blimmmm in you head :)
cheers
