lost_bro
Quote from: nelsonrochaa on April 14, 2016, 03:46:13 PM
Void ,
myself many times have some difficulties to linking and apply in practical my ideias;)  Is normal in research Work  because some of this informations are most of time "underlines" .
The most important sometimes is try to not let hour brain polluted because are so many information and different opinions about  this type of subjects .
about the post of Grumage with my old video is really a scissors  make contact with ground but in end of video in last minutes i show without ground , but that prototype are to old (8 months) but i  have that box yet in my home in Portugal, like other smaller basic circuits that i make  to record myself  that great things are made with first small results. :).
I think the important at present is understand how to replicate the extra coil circuit first and to that Last Bro start sharing a good information .
If we have a big problem , better don't try to solve that in one shot ; better divide the big problem in small parts and it will more easy the journey  until end :)
good luck
Good day Nelsonrochaa
When I read your comments on your post from yesterday, I immediately thought of Tesla's Iron core double ended 'extra' coil XFRMR from CSN.
Is this the information you are referring to?
What is your opinion on the placement of the *extra* coil?
What about perpendicular/90 degree angle to the secondary?
take care, peace
lost_bro
nelsonrochaa
Quote from: NickZ on April 14, 2016, 05:05:51 PM
  Nelson:
  Thanks for your comment, concerning the ground line, and it's uses.
  However, we have been working on the Ruslan/Akula replications, which uses the antenna as the " third, or extra coil". This antenna coil, has yielded no significant additional output, for most of us, as yet.  Perhaps Geo will be the first to show how it can work as was planned to provide for a self runner.  At least, I hope so.
    I have been working for years on simpler circuits,  to try to turn them into self runners.  Such as Joule Ringers, Joule Thiefs, Cross-Over circuits, Dr. Stiffler Exciters, Kacher circuits, as well as several others.
  How much simpler can it get? Yet, none of them produced more out than in, or are able to self run.
  I for one would like to find a project that works. And not to continue to waste time on what doesn't.
  So, we need much more than just hints, to find our way. We need a hand...  like yours.
Nick ,
You now exactly what iam evolved in moment i already tell you in PM , and "open the book" clearly is not for present time  and i think you understand that .
I think Ruslan or even Akula not have a full self run yet with a big power output , you could see by their changes in last months , but they understand how to make what Tesla explained like " a more economical way" to produce the higher output  that people call over-unity by the extra coil  effect .  I couldn't  talk by them but i compare with i have made until know ,  and i work in present time .
I already say that is impossible create a self runner if it not interact with a external source and act like a pump or siphon effect   , because all the circuits that you talk Joule ringers , stifler exciters work in a closed circuit without interact with external power source  but use their own power source even with improved result with less lost .
Only to you understand that is not a easy task tune that type of circuit , i lost several months until design my own exciter circuit capable to auto tune the resonant point in first stage of circuit. This is way you able to wear different bit notes in my circuit that i post months ago when is operate because the frequency is variable and adjust itself.
I already tell so much times ! not copy anything! Just read a bit first and think after how you will apply   !  In last posts i put important information about how Tesla use the extra coil and even  Lost bro posted too. That is important information! Is a big step to go higher flights , but without that you will remain in circles like last years with only a timid results waiting for Ruslan results or other.
If you able to make a circuit with high pressure output you will able to convert again in current but not by expenditure in input , need to extract that output by other away!
this is the reason way i say months ago  that is not need a karcher circuit and everyone ridicularize me  !
the first stage could me made by a simple iron transformer ! and if you think or someone tell you that will be heat in higher frequencies higher then  50HZ are wrong ! Only need to understand how to excite in the right way;   In that  notes from Tesla he said the same ! could be used a iron transformer and will remain cold !  if we pulling a rubber band to its limit it returns an opposing force until to return to its normal state or not ? is not obvious that ?  the power used to pulling are only positive but the opposing force ?
Need to to empty your head because some things will seems silly if you are a electronic engineer  and will difficulty everything .
Way we agreed that the current flows from positive to negative if it is exactly the opposite? but most only treat this subject like books said.
Hope make some light to you take you own path even it hard but think by yourself !
Big hug
NickZ
   Well Nelson we have been working with this "third coil" idea for a couple of years, now.  Nothing to report from it's functioning, as yet. We have also been trying to locate and utilize the magic syncronizational frequencies, but,  still no cigar.
   I have worked on my own version (not just a copy) of the Ruslan/Akula devices, by using the Mazilli/yoke/grenade/kacher set up. Which as I've shown is controllable to some degree. And the output from just this induction circuit can reach to over 2000v. And it was providing more lumins than any other of these similar type of devices, that any of us have built.
But, somehow, it's not to the needed degree, as I observe no additional output, than what is provided to it.
  Itsu has also made his painstakingly accurate version, but also has observed no additional output, or sync, to speak of.
  At this point in time, some of us are just about to abandon the ship, unless something new and exciting happens in the near future to change the course of our tests.  Some of us look like they have jumped overboard, already.
  So, now talk of fakes, and of other devices take over our discussions. Instead on continuing on with our project.  How sad...
GeoFusion
Hi Guyz :)
I finaly ready to run my setup again and have analog meters to see what is going on.
;D lets hope for the best.
Btw on the matter of Grounding of the Ruslan / Akula devices,
This Ruslan Video shows his 12V device working with ground and disconnects ground and circuit dies.
https://www.youtube.com/watch?v=OAgnnDWRVLI
Take a look :)
Hi Nelson, Greetings!
a.king21
During my conversations with kapanadze he dazzled me with his knowledge.  He knows Tesla's stuff backwards. Example: replacing
earth ground with the negative of a car battery is PURE TESLA.  (Yes I've read hundreds of hours of Tesla and he definitely states
this point).
He builds his own critical components and gets others to do the donkey stuff.
He destroys the critical ou components after every build.
When it comes to mechanical devices the lady in the bottom right designs the machinery according to Kapanadze's  specifications.
She does not know the secret either. (So she tells me).
