0 Members and 619 Guests are viewing this topic.
Hoppy
Quote from: nelsonrochaa on April 14, 2016, 06:14:35 PM
I already say that is impossible create a self runner if it not interact with a external source and act like a pump or siphon effect   , because all the circuits that you talk Joule ringers , stifler exciters work in a closed circuit without interact with external power source  but use their own power source even with improved result with less lost .
Only to you understand that is not a easy task tune that type of circuit , i lost several months until design my own exciter circuit capable to auto tune the resonant point in first stage of circuit. This is way you able to wear different bit notes in my circuit that i post months ago when is operate because the frequency is variable and adjust itself.
the first stage could me made by a simple iron transformer ! and if you think or someone tell you that will be heat in higher frequencies higher then  50HZ are wrong ! Only need to understand how to excite in the right way;   In that  notes from Tesla he said the same ! could be used a iron transformer and will remain cold !  if we pulling a rubber band to its limit it returns an opposing force until to return to its normal state or not ? is not obvious that ?  the power used to pulling are only positive but the opposing force ?
Nelson,
Thanks for your additional comments about your device. Although I think I understand how you are using your iron transformer, I don't understand how you are maintaining oscillation without some on-board power supply, especially if the earth is not essential for 'sucking-up' energy, as you show when you take the device for a walk about. Are you able to tell us whether you are using a small onboard battery power supply and if this supply is needed to produce the overunity? If this is the case, then it may open up new ideas for experimentation without using a Kacher, as per Kapanadze.
AlienGrey
Hoppy old fruit ;) if you read Teslas patents and notes you would know ! iron will very easily give up loose electrons if you bang it with a sharp pulse, but don't use the stuff in the garden or sling it at the sun unless you want to starve or put the sun out, also read about Viktor Schauberger (mountain man) German origin, it's all this shit in the water and our food that's dumbing us down GMO crops!
Tesla said using electricity is idiotic without using resonance !!!! I don't think Tesco or Asda do it ;D
Have you ever heard of a story about two WW2 Gi's one called something like Gutteridge, they came across a device something like a modified car dynamo that was powering a 100 Watt lamp, in order to recover 'it' he had to stop the unit by jamming the flywheel with his boot, he also kept the device for himself and got it transported home for later use where he copied it and sold copies to campers who stayed at his ranch. I can find nothing on it now but 8 or 9 years ago there were pictures of it on the net.
nelsonrochaa
Quote from: Hoppy on April 15, 2016, 05:14:17 AM
Nelson,
Although not sympathize with one another, to show you that there are far more important values in my person that you judge in other posts i will answer you:
point 1:
I never claimed he used only one iron transformer, but only in one stage of the circuit . Take a look in lecture shared some posts ago  about some notes of Tesla and extra coil possible configuration . Like we already "fight" is not a induction process what you search.
point 2:
In the prototype that you mention it is not used batteries but capacitors; but coils can act like a capacitor too, like for sure you know and others know . Tesla talk very well about that .Need to read again information about their patent of pancakes coil.(See again Tesla notes about using higher capacity in the primary)
Capacitors are able to work like a electrostatic container , and acting  like a coil, reversing their polarity and give the same back rush like a coil normally do, create another new different oscillation .
point 3:
The ground will always leading to increase efficiency and higher output  and easier to maintain synchronism in oscillation circuit.
In this particular circuit that you talk  sometimes the oscillator lost synchronization  causing the circuit to stop.
I need to provide again "fuel" to start the operation until synchronize again  (see atently the video again and you will see exactly that). Vamus already show exactly happens in their circuit.
But ground not required in a circuit with more evolved system operation.
It is necessary to first understand what actually happens.
Final point :
You don't understand how maintain a oscillation without a power source ...?  But  you think right!  It have a power source ! But not the common power source that usually people think like batteries . Need to think again  how the siphon process work in a water inside a tank when you siphon the water only with a first use of power  ,  and you will find your answer. After that only need to translate that understanding to this type of operation in a circuit .
I did not invent anything, just translate the same observation to my own circuit design. Other people find different ways to do it.
Good luck
nelsonrochaa
To everyone !
no more tips.  I already share enough to compromise  myself and make people decide what is better to each one .
Good luck to everyone.
Grumage
Quote from: AlienGrey on April 15, 2016, 07:09:54 AM
Dear AlienGrey.
I think you're referring to the " Lockridge device "........ Way off topic !!  ;)
I've been following along quietly and would like to announce a breakthrough........ 2KW...... Free energy device, easily replicated but only viable for 6/8 hour running time. Picture attached.   ;)
Now the hard work is done I can sit back and experiment. Nelsons last few posts have been cryptic, understandably so, but informative, thank you Nelson.
Cheers Grum.
