0 Members and 798 Guests are viewing this topic.
cheappower2012
AG
In order for the kapanadze device to be a real device you have to have  some good guesses where he got the idea from.The Parmeco type transformers would not be something
he would get a hold of in Georgia.Tariel Kapanadze was a poor common man in Georgia,
what he got ahold of would be common for hes area of the world.
One thing that goes in here is very simular to the tpu thread I was in for years,people are cheering
for the kapanadze device to be a Tesla invention,and want to believe Kapanadze,nearly everything that
comes out of hes mouth is a lie,it has a resonator,I can't get a certain cable,people jump at
every word he says and draw conclusions from that,total sillyness LOL.I don't believe aukla or ruslan
have anything but tricks.Do you have a link for the Stevie Kapanadze channel never heard of this.
apecore
Quote from: nelsonrochaa on April 14, 2016, 06:14:35 PM
Nick ,
You now exactly what iam evolved in moment i already tell you in PM , and "open the book" clearly is not for present time  and i think you understand that .
I think Ruslan or even Akula not have a full self run yet with a big power output , you could see by their changes in last months , but they understand how to make what Tesla explained like " a more economical way" to produce the higher output  that people call over-unity by the extra coil  effect .  I couldn't  talk by them but i compare with i have made until know ,  and i work in present time .
I already say that is impossible create a self runner if it not interact with a external source and act like a pump or siphon effect   , because all the circuits that you talk Joule ringers , stifler exciters work in a closed circuit without interact with external power source  but use their own power source even with improved result with less lost .
Only to you understand that is not a easy task tune that type of circuit , i lost several months until design my own exciter circuit capable to auto tune the resonant point in first stage of circuit. This is way you able to wear different bit notes in my circuit that i post months ago when is operate because the frequency is variable and adjust itself.
I already tell so much times ! not copy anything! Just read a bit first and think after how you will apply   !  In last posts i put important information about how Tesla use the extra coil and even  Lost bro posted too. That is important information! Is a big step to go higher flights , but without that you will remain in circles like last years with only a timid results waiting for Ruslan results or other.
If you able to make a circuit with high pressure output you will able to convert again in current but not by expenditure in input , need to extract that output by other away!
this is the reason way i say months ago  that is not need a karcher circuit and everyone ridicularize me  !
the first stage could me made by a simple iron transformer ! and if you think or someone tell you that will be heat in higher frequencies higher then  50HZ are wrong ! Only need to understand how to excite in the right way;   In that  notes from Tesla he said the same ! could be used a iron transformer and will remain cold !  if we pulling a rubber band to its limit it returns an opposing force until to return to its normal state or not ? is not obvious that ?  the power used to pulling are only positive but the opposing force ?
Need to to empty your head because some things will seems silly if you are a electronic engineer  and will difficulty everything .
Way we agreed that the current flows from positive to negative if it is exactly the opposite? but most only treat this subject like books said.
Hope make some light to you take you own path even it hard but think by yourself !
Big hug
Unless i'm not a expert in the case but something triggers me..... Nelson's statement is my first trigger... See quote
Second,.. the discussion about TK "hidden" component.... Capacitor?,...  exciter?... by Nick...
It must be simple, must can stand HV,.. needs to resonance within the coilresonance but must not be "direct" coupled..
It is a coil,.. acapacitor,... exciter,...  and has to generate a big spectrum (frequentie),...  but for all it must be constructable with scrap (as TK does)
Please think about it,.....could it be that the missing component is a tesla bifilar coil with spark cap,...acts as a capacitor and also as a coil?
Illustrated in the attached picture?
Could this tesla bifilar coil be placed in the grenadecoil as the "inductor" shown in the Akula coil setup (see attached picture)
Cheers
apecore
Quote from: apecore on April 16, 2016, 04:34:01 PM
Cheers
forgottoattach the picture..
a.king21
Why don't you all read Kapanadze's patent application.
And listen to Nelson Rochaa.....
Void
This is a picture that Birom posted of the 220V generator which Gocha Tabatadze
(claimed Tariel Kapanadze's cousin) demonstrated a number of years ago before he passed away.
I believe this may be the same generator which Tabatadze is claimed to have demonstrated at the aircraft
factory in Georgia powering 8 kW of load. It apparently did not require an earth ground.
Unfortunately the picture is low res and a bit far away from the generator. Birom stated that this particular
generator made by Tabatadze was a different configuration than Kapanadze's devices. Birom also mentioned that
there were some attempts to steal this generator from Tabatadze's apartment at that time.
