0 Members and 1510 Guests are viewing this topic.
x_name41
Quote from: Void on April 17, 2016, 03:20:32 PM
Hi x_name41. So the main MOSFET that drives the bulb directly is being
driven at 50HZ and 1% duty cycle, but what frequency and duty cycle should I switch the
MOSFET switch for the choke coil at?
I am going to go out for a while and see if I can pick up a 12V low wattage car filament light bulb to
try this test. My 12V, 35W halogen bulb is probably not suitable for this test...
second switch is a hand manually switching, frequency unknown
apecore
Quote from: NickZ on April 17, 2016, 02:38:07 PM
   What is that picture from apecore above about?  I seam to have missed the description?
NickZ,... its a pancake tesla coil from wrapped aluminium foil....its what is described beginning at page 3.4 in the following link.
http://www.free-energy-info.com/Mohamed.pdf
I think this could be the missing part.
Nelson was right by saying  "he told a lot"....  please convince me if not. ;D
The following quote's inspired me after putting the puzzle together.
Quote from: NickZ on April 16, 2016, 12:04:09 PM
  Could the "resonator" in the green box be the "third coil"? As there is no such thing on the observed Tesla coil of his first device, yet there is on the last video.  He mentioned resonator as being the secret component.  Not a capacitor using magnets.
Especially Nelson following quote,...
Quote from: nelsonrochaa on April 13, 2016, 06:06:19 PM
"Owing to this feature I expect that this method of raising the e.m.f. with an open coil will be recognized later as a material and beautiful advance in the art. No such pressures — even in the remotest degree, can be obtained with resonating circuits otherwise constituted with two terminals forming a closed path. It is also a fact that the highest pressure, at a free terminal, is obtained in that form of such apparatus in which one of the terminals is connected to the ground. But such "extra coils" with one terminal free may also be used with ordinary transformers and by using one such coil on each of the terminals of the transformer, practically any spark length may be reached"
"As has been stated on a previous occasion in connection with this subject, to enable a considerable rise of pressure to take place in a circuit, the same must be tolerably free from inductive influences of other circuits. It follows from this that, although with a secondary in loose connection with a primary a very high pressure is obtainable, yet the pressure will never be as high as when an "extra coil" not in inductive connection with the primary is employed to raise the pressure, because the secondary always reacts upon the primary thus dampening the vibration, while the "extra coil" does not react in such a manner, the rise of pressure being simply due to the factor pL/R."
"Obviously the maximum rise will take place when the period of the excited system or "extra coil" is the same as that of the oscillating system impressing the movement, for although the results obtained with a lower or upper harmonic, and particularly the former, may be sometimes so remarkable, as to be mistaken for effects of the true vibration, they are nevertheless always inferior, and I as a rule try the first upper and undertones to be sure of the result, when there exists any doubt in this respect In ordinary practice the first element which is given will be the frequency, hence the wave length must be assumed as the first fixed quantity."~
NickZ,...  i must admit,..... for me you where very helpfull in summerising the mean topcis
Quote from: NickZ on April 14, 2016, 05:05:51 PM
  Nelson:
  Thanks for your comment, concerning the ground line, and it's uses.
  However, we have been working on the Ruslan/Akula replications, which uses the antenna as the " third, or extra coil". This antenna coil, has yielded no significant additional output, for most of us, as yet.  Perhaps Geo will be the first to show how it can work as was planned to provide for a self runner.  At least, I hope so.
    I have been working for years on simpler circuits,  to try to turn them into self runners.  Such as Joule Ringers, Joule Thiefs, Cross-Over circuits, Dr. Stiffler Exciters, Kacher circuits, as well as several others.
  How much simpler can it get? Yet, none of them produced more out than in, or are able to self run.
  I for one would like to find a project that works. And not to continue to waste time on what doesn't.
  So, we need much more than just hints, to find our way. We need a hand...  like yours.
After this quote from Nelson it was clear to me....
Quote from: nelsonrochaa on April 14, 2016, 06:14:35 PM
Nick ,
You now exactly what iam evolved in moment i already tell you in PM , and "open the book" clearly is not for present time  and i think you understand that .
I think Ruslan or even Akula not have a full self run yet with a big power output , you could see by their changes in last months , but they understand how to make what Tesla explained like " a more economical way" to produce the higher output  that people call over-unity by the extra coil  effect .  I couldn't  talk by them but i compare with i have made until know ,  and i work in present time .
I already say that is impossible create a self runner if it not interact with a external source and act like a pump or siphon effect   , because all the circuits that you talk Joule ringers , stifler exciters work in a closed circuit without interact with external power source  but use their own power source even with improved result with less lost .
Only to you understand that is not a easy task tune that type of circuit , i lost several months until design my own exciter circuit capable to auto tune the resonant point in first stage of circuit. This is way you able to wear different bit notes in my circuit that i post months ago when is operate because the frequency is variable and adjust itself.
I already tell so much times ! not copy anything! Just read a bit first and think after how you will apply   !  In last posts i put important information about how Tesla use the extra coil and even  Lost bro posted too. That is important information! Is a big step to go higher flights , but without that you will remain in circles like last years with only a timid results waiting for Ruslan results or other.
If you able to make a circuit with high pressure output you will able to convert again in current but not by expenditure in input , need to extract that output by other away!
this is the reason way i say months ago  that is not need a karcher circuit and everyone ridicularize me  !
the first stage could me made by a simple iron transformer ! and if you think or someone tell you that will be heat in higher frequencies higher then  50HZ are wrong ! Only need to understand how to excite in the right way;   In that  notes from Tesla he said the same ! could be used a iron transformer and will remain cold !  if we pulling a rubber band to its limit it returns an opposing force until to return to its normal state or not ? is not obvious that ?  the power used to pulling are only positive but the opposing force ?
Need to to empty your head because some things will seems silly if you are a electronic engineer  and will difficulty everything .
Way we agreed that the current flows from positive to negative if it is exactly the opposite? but most only treat this subject like books said.
Hope make some light to you take you own path even it hard but think by yourself !
Big hug
There were a lot members a vew days ago busy with explaining the "third coil"... in my opinion a explained tesla bifilar (capacitor) coil has almost all the aspects of what you all where talking about.
If not so,...  please tell me i'm wrong.
verpies
Quote from: x_name41 on April 17, 2016, 03:45:53 PM
So coinciding with the 1% conduction period of the MOSFET would appear random.
T-1000
Quote from: x_name41 on April 17, 2016, 02:29:07 PM
frequency=1Hz, duty cycle=50%, Rgate=47k
frequency=50Hz, duty cycle=1%, Rgate=47k
frequency=50Hz, duty cycle=50%, Rgate=47k
The deviation from Dally replication topic, just would like to share something useful...
As you are already playing with BEMF, here is idea about modulated coil switching from akula:
https://youtu.be/_eQg4TLrfjc?t=8m39s
This will recover much more BEMF than just from single pulse.
Cheers!
Void
Ok, thanks. I will give it a try...
