0 Members and 75 Guests are viewing this topic.
Сергей В.
NIKZ Upper trace output of 555 generator - lower trace output one of divider by 9 (one of 3 dividers) which trigger optocouplers and they trigger Power Thyristors. 3 branches with apropriate phase shift. Experiment with Air core choke !!
NickZ
 I have been experimenting with the air coil choke, using 12 turns, and also using about 250 turns magnet wire Exciter type coil as the choke, nothing yet. I will try different caps.
  If I use a single transistor pulse circuit direct to the resonator coil, that is wound on top of the big air coil, I do get some output. But, less than if not using the air coil, as the ferrite rod is outputting about 1500v.
But, not through the yokes 3 turn output coil, as there is little voltage/current coming out of it to the big air coil. I need to know the cap values, also.
I'm not interested in the feed-back circuit until I can obtain some output from the air coil/choke set up. Although the 12 turn feed back coil is already made and mounted, but I need the cap for it, and rectifier, etz...
  If the video is real, then we need to focus on it, and not the hand drawn diagram, which may not be right, or any other diagram, as they may all be misleading.
anandml
@NICKZ Pls compare this Picture Maybe he placed yoke device inside the big tube
anandml
Quote from: NickZ on May 15, 2013, 09:19:03 PM
You are right nickz we need to focus on the video and drawn our own diagram....
verpies
Quote from: NickZ on May 15, 2013, 07:18:04 PM
Main thing is that he does show the scope shots, and can possibly do so again. Maybe clearer, next time, along with answering any other questions that we may have.
Yes the mere presence of scopeshots is encouraging. Is it one of his old videos before the "chair device" or a new one (filmed after the "chair device" ?).
If Mr.Shark (Akula) publicly cooperated with me like Itsu did at the beginning of this thread, we would have the Modus Operandi and repeatable building instructions within a week.
The contact has been made with Akula 0083.
Really?  In what language?
At this address: akula0083@mail.ru ?
Can he post on this forum even in Russian language ?
It's supposed to work, but we need to know more, especially about the choke. Does it use an aluminum liner, what size former, how many winding, gage, turns, cap? Etc...  These are not outrageous questions.
Indeed they are not outrageous questions.
The construction of the coil together with materials used for it, is the most difficult.
Along with voltage points, and whatever else.
The electronic circuitry can be built in many equivalent ways if the schematic and I&V Scopeshots are known.
I don't have a scope, and don't want one either,
Electric waves are invisible. It's not good to be blind.
unless it's free, or like a Pc scope. But, I'm out in the jungle...
How do you deal with the heat and insects?
BTW: What is the most popular dance where you live?
So, we need someone to do the scope thing, and help us all to know how to build it, like as if it were a kit.
Akula has a scope so he can do it if he cooperates like Itsu.
If I knew what to aim for I could make such clear instructions (or a kit) that even a child could build it.
Maybe someone can draw up a clear schematic, with all the specs, and values.
That cannot be done from the low resolution videos. Even with high resolution and a lot of zooming, it would be very hard when one component covers another or its connections.
So if Akula is not willing to draw and post a schematic or let me or someone else travel to his place and draw it for him, we will never have a sure and complete circuit layout documented :(
